transmission swap
94stangraygt
im going to swap my transmission out. i burnt out my 3rd gear. i just pulled a 5.0 tranny out of a wrecked gt. it is a manual and mine in my car now is an automatic. what all parts do i need? and what is a good price to install it?
upper shift boot
lower shift boot
tranny(of coarse)
bell housing
shifter
shifter knob
driveshaft
flywheel
clutch cable
clutch pedal assembly
shift fork
clutchdisc
pressure plate
all bolts(flywheel to crank,pressure plate to flywheel,bellhousing to block,tranny to bell housing.)
block seperator plate(goes between the block and bellhousing)
5 speed PCM
5 speed tranny wiring harness.
you can reuse your tranny crossmember
thats all i can think of off the top of my head.
as for the install price,i could'nt tell you.i did it myself
good luck,you wont be disappointed with the conversion.much more fun to drive a stick:nice:
Be sure to get all the parts before you start, or have access to another car. ;) Be sure you get the T5 from a 94-95 GT, or it won't fit right. The input shaft is shorter on the 86-93 Stangs, it won't fit our cars.
