Transmission
  • Thread starter Thread starter snakebite01
  • Start date Start date Nov 8, 2008
snakebite01
81
new jersey but not for long
Nov 8, 2008
  • Nov 8, 2008
Will the t-45 trans out of the sn95 mustangs mount up to the 92 5.0 block?? what mods will i have to do? and what problems will i be running into while doing this??
the reason why i am asking is because i can get a t-45 that needs a new tail shaft housing for free, it's either that or i can get a t-5 for 400 from a local auto parts/ junk yard.
-Matt
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Nov 8, 2008
  • Nov 8, 2008
400 for a JY T5 is a little steep.
snakebite01
81
Nov 8, 2008
  • Nov 8, 2008
that's what i was thinking,, i know junk yards sell them for 175 but trying to find them is hard.. what other cars could i pull a man. trans out of that will work in a 92 gt?
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Nov 8, 2008
  • Nov 8, 2008
you could use a 4cyc t5 if your in a bind.
94-95 t5 will work if you use the 94-95 bell housing or swap the input shaft out to a 87-93 style.
snakebite01
81
Nov 8, 2008
  • Nov 8, 2008
i'll keep that in mind..
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Nov 8, 2008
  • Nov 8, 2008
I done a quick search on yahoo. Someone on another mustang site says that the t45 can be used but you need a special adapter plate in order to install it. He also said the t45 is not any stronger than the World class T5. No mention of where to buy a adapter plate. Im sure that by the time you fix the t45 and buy the adapter plate etc etc it would be cheaper to buy a new t5.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 8, 2008
  • Nov 8, 2008
You need an expensive adapter plate
T-45 is rated at 330 ft-lbs.
snakebite01
81
Nov 9, 2008
  • Nov 9, 2008
where can i get this "expensive adapter plate"??
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
D
Ford AOD Transmission filler tube orings
  • Dagasser
  • Jul 21, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 26, 2026
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
