Hey all (need some quick input if possible)!
I also posted this in my old thread titled "Tremec 3650 Fluid "! Just didn't know if it would get seen as quick as a new thread!
I just got done doing a tranny fluid change on my TR3650.
I ended up going with GM Synchromesh Penzoil brand #123453??, allot of people swear by it so I thought what the heck...."I'll give it as shot"!
Ok So I Drained the old fluid out (via drain plug). I also removed the fill plug located above drain plug on Passenger side (Didn't fill from it though....went through shifter)!
Ok my reason for posting is......
I have heard that 3.2 quarts are used to fill the trans.
Some say add fluid until it comes out the fill hole, others say fill slowly until you can feel the fluid by sticking your finger in the fill hole!
Well I poured 3-1/2 bottles of penzoil syncho in the trans and no fluid came out the fill hole, nor when I checked it could I feel the level by sticking my finger in the fill hole. I stopped at 3-1/2 bottles because I didn't want to over fill the trans!
I haven't driven the car much (about 3 miles) and it seems to be shifting fine and sounds about the same as before the change (no weird noises). I just want to verify with you guys that I have put enough in (don't want to blow the tranny on my 50 mile commute to and from work Monday)!
What do you guys think......add more and let it as is??????
