I bought a tko used from a dude on here. It came with a pro 50 shifter and I re-used my hurst handle. I bought ALL the stuff do it right. I got a mcleod scattershield, mcleod dual friction disk, king cobra pressure plate, aluminum driveshaft with 31 spline yoke, t/o bearing, pilot bearing, rear main seal, speedo gear, prothane trans mount, GM syncromesh fluid and a new 1.4kw PA perf starter. Its a little different from a T5, the gears are closer and it feels tighter. My clutch set up is absolutely awesome!! NO chatter and lighter pedal than the fms HD. It just feels good, im very glad I went this route. I got exactly what I want, a VERY strong clutch combo with a softer pedal.
The things im unsure of are, the tranny howls. For instance, say im in 2nd gear and i take it to 2500 and let the rpm's come down, it'll howl kinda loud. Also, im the hwy in 5th giving it extra gas to pass someone it howls as well. Are tremecs supposed to do this?
I also have a slight leak @ the output seal. If I replace the seal, im hoping this is an easy job. Just pull ot the driveshaft and pop the seal and replace?
This tremec is just big and beefy and the scattershield is huge too. Its very close to my header on the passangers side. I put a piece of rubber in between because it would hit the header at idle and it was annoying. I am glad I paid a dude to do this, this is definatly NOT a job to try at home if you want it done fast and its NOT a job for someone with no patience (like me
) I got a very fair price. Since getting the car back, I noticed it sounds different inside. Its hard to explain.
Im gonna try and take the shifter out in the afternoon and put silocone around it where it bolts to the trans. I dont think he put any on. Im thinking that might help dampen some noise I hear??
Mike
) I got a very fair price. Since getting the car back, I noticed it sounds different inside. Its hard to explain. Im gonna try and take the shifter out in the afternoon and put silocone around it where it bolts to the trans. I dont think he put any on. Im thinking that might help dampen some noise I hear??
Mike
