  • SN95 4.6L Mustang Tech
Tri-Ax getting sloppy
  • Thread starter Thread starter JerseyTrueBlue
  • Start date Start date Mar 1, 2010
J
JerseyTrueBlue
56
New Jersey
Mar 1, 2010
  • Mar 1, 2010
Since I bought my car it has had Steeda's Tri-Ax shifter in it. I have never really checked it out, just know it's there from pulling the plastic housing for the boot to fix the cigarette lighter. Lately the shifter has been feeling very sloppy and going for gears is a little more difficult because of how loose it feels. I've noticed in neutral the shifter rocks back and forth a bit more then it used to before you actually start tugging on the linkage. It just sort of flops back and forth about a good inch or so. Anyway due to this I'm getting choppy gear changes when I shift quickly, is there a bushing of some sort or something that could wear out over time and make my shifter loosen up? Or anything for that matter that would make the shifter have more play in it?
G
GettinThere
553
Central Texas
Mar 1, 2010
  • Mar 1, 2010
Obvious question, have you tightened the handle bolts?
J
JerseyTrueBlue
56
New Jersey
Mar 1, 2010
  • Mar 1, 2010
Lol hey it's a good one and yes the bolts are tight, that's why I'm thinking it has to do with something further down from the handle. No one else has any input on this?
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Mar 2, 2010
  • Mar 2, 2010
Take the shifter off and fully check it out, make sure everything is tight. If it is, then most likely you have to look at the tranny.
04GreyGtUSAF
43
KS
Mar 2, 2010
  • Mar 2, 2010
Im kinda in the same boat.......just has a bit more play in it in neutral than it did new. I have about 40,000 miles on the tri-ax. If i can pull it this week to take a look. I may try buying another.
G
GettinThere
553
Central Texas
Mar 2, 2010
  • Mar 2, 2010
I think there is supposed to be a small (black) plastic sleeve over the metal ball end of the shifter, that extends down into the tranny. Maybe that has cracked or is broken or missing.
I
iMTB
12
Florida
Mar 2, 2010
  • Mar 2, 2010
I think I'm the only one that likes the stock shifter...
ChillPhatCat
20+ Year Stangneter
Apr 22, 2002
409
65
48
Syracuse, NY
Mar 2, 2010
  • Mar 2, 2010
I'm a fan as well, so that makes two of us at least.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Mar 3, 2010
  • Mar 3, 2010
send it back to steeda they will rebuild it for free..
J
JerseyTrueBlue
56
New Jersey
Mar 4, 2010
#10
  • Mar 4, 2010
  • #10
Even if I bought the car with it on there they will fix it up?
Tripoli
208
Dallas, TX
Mar 4, 2010
#11
  • Mar 4, 2010
  • #11
Most shifters loosen up over time. Both of my Tri-Axes did. MGW does not. I beat the crap out of mine and it's still rock-solid.
I
ItsStock02
492
Westland, MI
Mar 4, 2010
#12
  • Mar 4, 2010
  • #12
I liked the stock shifter until I installed my tri-ax. Lol
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Monday at 8:59 AM
squeak93
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
