  • SN95 4.6L Mustang Tech
Tri-ax Install Problem
  • Thread starter Thread starter Mach1Run
  • Start date Start date Aug 7, 2004
Mach1Run
333
Wylie, Texas
Aug 7, 2004
  • Aug 7, 2004
Ok I have a 2001 GT and I stopped by DMP yesterday and picked up a Tri-ax for a weekend project. Following the instructions in the box I got the stock shifter out with no problem. However, when I try and set the Tri-ax in it will not sit flush on the case, there is a quarter inch gap or so between the shifter and the housing. I got to looking at the old one and the tri-ax and noticed the shaft on the triax seems to be longer than the stock one. I know I ust be missing something easy but could someone point it out for me.
sabrooks
228
Phenix City. Alabama
Aug 7, 2004
  • Aug 7, 2004
do you have the right shifter? They changed transmissions in 2001 that could be your problem
twogts4us
4,188
12
79
Dunedin, FL
Aug 7, 2004
  • Aug 7, 2004
Decode the sticker on the driver's side door post here ---->http://web.tampabay.rr.com/theflock/mustang/doorplate.html
Sounds like what sabrooks said, wrong shifter.
Mach1Run
333
Wylie, Texas
Aug 7, 2004
  • Aug 7, 2004
I think so, they looked up which one I was supposed to need when I went in. And the instructions say T5, T45, TR3650. From looking at the pics I would say there is a 3650 in the car.
Mach1Run
333
Wylie, Texas
Aug 7, 2004
  • Aug 7, 2004
Ok I checked the door sticker and now I'm really confused. It doesnt really match the one in the decoding link above. The 5 digit code is 1ze2g with T05 under it. Anyway I took a picture of the shift housing, which is fuzzy but maybe good enough to tell, and my door sticker.
http://www.geocities.com/war_mouseus/shift.html
crew_dawg16
445
DeKalb, IL
Aug 7, 2004
  • Aug 7, 2004
did you take the plastic piece off the old shifter and put it on the new one? Also, make sure you are lining up the shaft (I said shaft) and the hole in the top of the tranny
Mach1Run
333
Wylie, Texas
Aug 7, 2004
  • Aug 7, 2004
yup checked both of those again just to be sure.
I
inferno9898
249
Aug 7, 2004
  • Aug 7, 2004
on that label that you posted, under the TR heading it says K, which the link says is the tremec trans.
you've probably got the T-45 shifter
rpayne20
77
MI
Aug 7, 2004
  • Aug 7, 2004
I would call ford with the numbers from the doorpost decal and let them tell you what you got....I am sure they can tell you what you got...maybe even a good auto parts store.....just my 0.02
Mach1Run
333
Wylie, Texas
Aug 7, 2004
#10
  • Aug 7, 2004
  • #10
worse comes to worse Ill put the old one back on and drive it over there monday morning and take it apart in the parking lot and have them figure it out lol.
I
Ilsimen
52
Wichita, KS
Aug 7, 2004
#11
  • Aug 7, 2004
  • #11
Mach1Run
333
Wylie, Texas
Aug 7, 2004
#12
  • Aug 7, 2004
  • #12
The conclusion I have come to, from looking at the pictures in the instructions is that I have a 3650. However the box is labeled as being for the T5/t45, which is what the salesman at Dallas Mustang thought I had as well. Anyway I am just going to take it back after I get off work monday and take it back over to DM. I put the old one back on except for the leather boot and packed the sockets in the trunk so we can take it off there if they need to look at it.
Thanx for your suggestions
I
inferno9898
249
Aug 7, 2004
#13
  • Aug 7, 2004
  • #13
lol the sticker on ur door says you have a 3650....you just aren't reading it correctly i think. it isnt in the 5 digit code. look for the letters TR. underneath is the letter K. read the link posted above and it states what the K stands for.
Mach1Run
333
Wylie, Texas
Aug 7, 2004
#14
  • Aug 7, 2004
  • #14
Oh now i see, I thought the 5 digit code said the transmission. The example has a 5 digit code under TR so thats what i was lookin for, 5 digits together not 1 then a blank and 4 more. doh!
greensix <-- Professional noob
Snarf
237
Lexington, KY
Aug 7, 2004
#15
  • Aug 7, 2004
  • #15
You have a T3650 Trans, I'm 100% sure of it. For one, half the 01's made came with them, and secondly, I just had my 99 [equipped with a T45] open 2 weeks ago to install mine and it looked nothing like the pic you posted. You definetly have a T3650. If your shifter isnt fitting perfectly, they had to have given you a shifter for a T45. Take it back and get the correct one and you'll be golden
twogts4us
4,188
12
79
Dunedin, FL
Aug 8, 2004
#16
  • Aug 8, 2004
  • #16
Damn, OK, well I'm glad you guys finally figured it out. I was the one who had provided the link to the VIN/VCL decoding webpage. I was like, come on guys, I gave you the info up there!!!!
Anyway, the quick and dirty for anyone else - under the TR on the VCL (Vehicle Certification Label on the driver's side post), a "6" denotes a T-45, a "K" denotes a TR-3650. That salesman really should have known to ask you and been able to tell you how to find out what you have. This is Dallas Mustang, specializing in Mustangs?!?! Shame on them!
Mach1Run
333
Wylie, Texas
Aug 8, 2004
#17
  • Aug 8, 2004
  • #17
Heh thats what i get for assuming he knew more than I did lol. He asked if I knew and I told em I had no idea but it was parked outside if we needed to go find out. He went with whatever the computer said DOH! Partially my fault too cause I should have done a little more research first but I didnt.
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
