I just did the install Saturday, an easy way to break the seal is to use a small claw hammer, get the claws on the lip of the stock shifter base and pull up..worked like a charm. Oh and a really good tip, i used some rubber from a bicycle tire between the handle and base...helped allot with noise and heat transfer....make sure you use loctite on al bolts..
