Tri-Y clearance issue ?'s
damannhw
173
Upstate SC
I just installed some ceramic coated try-y's I bought from Mustangs Unlimited. Drivers side looks great, but the passenger side not so great. The #1 cylinder tube rubbed the shock tower. I used the old reliable hammer and flattened the tube slightly. I now have about 1/8" clearance or so. It looks great everywhere else. Is this normal, or acceptable ? I'm having the new exhaust done tomorrow, so I won't get to drive it until Friday evening. I'm worried about the header hitting under load. Any experiences out there ? Thanks
I've heard of "redesigning" the bends by bolting the headers on without gaskets, then using your foot to apply enough pressure to the collector to bend the tubes. I haven't tried it - use this method at your own risk!!
remember that these cars are not dimensionally accurate. you are likely running into "tolerance stack". you can make a few adjustments as mentioned, and run a torque strap as well.
