Tri-Y touching
  • Thread starter Thread starter 1fstpony
  • Start date Start date Jul 9, 2005
1fstpony
76
Iowa
Jul 9, 2005
  • Jul 9, 2005
I have a 66 fastback that I have put a 302 in and my pass. side header just barely touches the shock tower.I have TCP motor mounts in the car also.I was wondering what I should try,I was thinking on shiming the motor mounts just a little.Does any one have any other ideas or sugestions.Thanks
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jul 10, 2005
  • Jul 10, 2005
Shiming the motor mounts will normally give you more clearance with the shock towers. Possible problem with this method is that the air cleaner could hit the hood if you have an extreme high rise intake manifold. Another possible problem, although unlikely with most headers, is that the collector could hit the floorpan's front support.
In the past I avoided massaging the shock towers but recently decided that it was a better option than flattening a header tube. I know that everyone has there opinion on hammering on their car for clearance, but the shock towers, especially the 2 outer areas that bulge, will reshape easily. This mod can easily be reversed with a little light hammering from the wheelwell. It was much easier to do than I envisioned and is not as noticeable as a dinged header.
The only remaining thing you can do is massage the header a little.
jerry S
1,365
52.22N 5.12E
Jul 10, 2005
  • Jul 10, 2005
do you have a shock tower brace? Headers touching the shock towers is usually due to shock tower sag. the sag can be reversed a bit with the installation of a shock tower brace.
1fstpony
76
Iowa
Jul 10, 2005
  • Jul 10, 2005
I think I'm going to try loosening all the bolts on the mtor mounts and see if I can't get the motor to slide toward the driver side a little and wedge something on the pass. side to hold it until I can tighten the bolts back up.
Cobain03
996
Lexington, Ky
Jul 10, 2005
  • Jul 10, 2005
haha that problem is cake to what i wen tthrough. for those who was here a long time ago, mine was being hit by the pitman arm. i could NOT turn left. my motor ended up being shimmed like 3/4 of an inch and my headers on that side was torched and bent.
so shim it, or if that dont work, torch it
1fstpony
76
Iowa
Jul 10, 2005
  • Jul 10, 2005
I loosened all the bolts on the motor mounts and got the engine to slide over about a 1/4" and now it's going to be ok.Is that enough clearance?I don't have a big cam,so I hope it will be ok.
C
chemeng
93
Louisville, KY
Jul 10, 2005
  • Jul 10, 2005
I don't like the old '65 mounts, just not enough clearance and the engine sits too low. I gained about 1 1/4 inches in engine height by switching to the '66 motor mounts, they are sometimes called the "tall" mounts. Had to reposition my fan shroud afterwards but now have plenty of room for headers.
My old mounts were shimmed 1/2 inch and would "creep" to the passengers side, the washers were sliding on each other.
MikeR
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Jul 11, 2005
  • Jul 11, 2005
I had the same problem with my Tri-ys and same mounts. There is room to shift the motor a little. The motor mount directions also said you might have to grind the bottom bolt heads for clearance.
iskwezm
4,159
20
79
Rowland Heights,California
Jul 11, 2005
  • Jul 11, 2005
Thats what i did and also used a couple of thick washers under the motor mounts and a engine strap to pull the engine away.
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
P
Hello, core supports for '86 vs '90-3, i need some answers if anyone knows
  • Pony Dr.Mike
  • Mar 14, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 15, 2026
95steedamustang
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
T
New here, just saying hi.
  • Tank Mechanic
  • Nov 1, 2025
  • The Welcome Wagon
The Welcome Wagon Nov 2, 2025
nickyb
