Trick Flow Cam!
  • Thread starter Thread starter adam21
  • Start date Start date May 28, 2009
A
adam21
  • May 28, 2009
Ive got a cam trick flow cam, i bought to go in my car. I just need to know if it will fit in engine without changeing anything major? Its a TRICK FLOW ROLLER CAM FOR 5.0 - 5.8 IT IS A STAGE 1 ROLLER CAM DURATION IS 275/279 LIFT IS .499/.510
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
May 28, 2009
  • May 28, 2009
It should definitely fit in a stock engine, but if you're putting it in with stock heads, I have a feeling you're going to be quite disappointed that you didn't pick up very much power.
A
adam21
  • May 28, 2009
im not looking to pick-up alot of power. im just looking for a better sound
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
May 30, 2009
  • May 30, 2009
Changing the cam if an awful lot of work to get sound.
I wouldn't do it.
Besides if your valve springs are old, the cam will help wear them down in no time.
Way back i made the mistake of putting a cam in my stock engine, it was senseless.
the pony boy
358
May 30, 2009
  • May 30, 2009
if your car is stock wait till you get some heads and a intake.like the others have said its alot of work and you will most likely lose power.
thumper460
3,022
Orange Park , Fl
May 30, 2009
  • May 30, 2009
You WILL need springs!! IF you can change them out also.. you will have what you want! Just there will be more power with a set of heads or better intake is fitted!! cool??
Just me..........................
Thumper
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
