are the trick flow heads rpm better than my gt-40 cast iron heads and will they help in my quest of high 12's
i was going to say . . . . he does not need heads to run 12sGrn92LX said:You have MORE then enough for 12's now with what's in your signature.
stangjunkie said:no.. your HP seems low.... maybe its just me
Suspension is a friend in the drag racing scheme of things however i got to the mid 11's with out a drag racing suspension. I just threw more power at the car till it made 11's. I wonder what i could do with a drag racing set up.CAMAROEATER01 said:suspension is what you need my friend... get that power to the ground and you will see 12s
coupecop said:i already have bbk upperand lower controll arms and lowering springs plus subfram conectors.
