Trick Flow Stage 1 cam HELP!!!!
You're not going to notice much of anything with that cam until you either swap out those heads or have the stock one's ported. The bottle neck in SBF's is the heads. Get the heads to breath and watch the cam come to life. You'd be better off spending the money on gears first.
As far as having someone do it for you, it all depends on who you talk to. Its all labor. If the guys competent it won't take more then an afternoon.
Pick up a manual and do it yourself. Its how the rest of us learned.
If you are looking for more power I doubt you will gain much... probably loose power...(assuming you don't have any supporting mods no sig.) For the ammount of work and money involved, there are better gains elseware to be had. Good choice on cams though. It's hard to beat the performance of the stage 1 as far as an off the shelf cam in its class and definately price.
Kevin
yes they work with the stock heads but trie to port then so you can feel big difference and a stree heat is a good choice or typhoon intakes! and get 3.73 gears....
