Modular2v Founding Member Jun 30, 2002 3,222 23 99 oklahoma Oct 25, 2005 #1 Oct 25, 2005 #1 how would this cam fair on a 331 with afr 185s and forged flat top probe pistons? im guessing i would need some notch work done?
T tjm73 Founding Member Aug 3, 2000 2,418 2 48 Rush, NY Oct 25, 2005 #2 Oct 25, 2005 #2 TF Stage 3 won't idle at less than 1000rpm in a 418W with ported Trick Flow R heads in my brother's Ranger. In a 331 it'll need to idle higher I believe. Stage 2 might be better. I PM'd you BTW....
Modular2v Founding Member Jun 30, 2002 3,222 23 99 oklahoma Oct 25, 2005 #3 Oct 25, 2005 #3 so a stage 3 would be a bad choice for a car that i drive 200miles a month? it has a 750holley dp
T tjm73 Founding Member Aug 3, 2000 2,418 2 48 Rush, NY Oct 25, 2005 #4 Oct 25, 2005 #4 Modular2v said: so a stage 3 would be a bad choice for a car that i drive 200miles a month? it has a 750holley dp Click to expand... it probably work fine, btu may be a bit much for the combo. A custom cam might be the best option OR the Stage 2 option I PM'd you about. Just my random thoughts.....
3 304billet Member Sep 16, 2005 315 1 16 Oct 25, 2005 #5 Oct 25, 2005 #5 Comp cam XE282HR is a great cam in a 331 or 347. The Probe FT r double flycut for either a TW or inline Ford head, no notching needed.
