Trick flow street mannifold???
slayerripkdc
1,341
brewster ny
Hey guys, my mods are in my sig.... Will i gain any seat of the pants pull with the trick flow street mannifold and also will i gain any tenths in the 1/4??? also is it a pain in the butt to install or is it straight forward
manifolds are easy to install, just make sure u clean the surface very very well and dont let alot of coolant leak into the oil pan. dont forget to do an oil change after it as well.
you will probably see a small HP increase but dont expect much, the heads and cam should be changed with it for optimal performance.
you will see more tourque than hp i would also throw some harland shard RR's on there too.(while you got it down) that will help the heads breath better with that new intake you should also notice a deeper exhaust note.
