I am about to install the heads and it came with arp head bolts. The trick flow guide says nothing about using oil on the threads it just says to use some thread sealer then has a torque sequence of 35 50 70 then 10 more on the top bolts. Then the little paper that came with the arp bolts said to use arp moly lube and torque to 60 ft lbs. So which should i do??
