Trick Flow Twisted Wedge valve springs
Springs:
1.470 in. diameter single with damper
110 lbs at 1.800 in. installed height
Open Pressures: 290 lbs at .500 in. lift and 305 lbs. at .540 in. lift giving 360 pounds per inch spring rate
Maximum Recommended Lift:
.540 in. max valve lift
Alright, I guess I was misinformed then. I'm getting a set to use with my new motor and I was told by someone who supposively is a dealer for them that the TF stage 1 cam wouldn't work unless I upgraded the springs. Thanks guys.
