I have decided that I will be getting the trickflow top end kit from summit racing for 2249.95 + shipping or from ebay for 2249.98 including shipping, at summit and trickflow they recommend a 70mm throttle body, the kit on ebay says to use a 75mm throttle body, summit doesn't have a fuel pump recommendation but trickflow says to use a 190 and the one on ebay says 255, and trickflow and ebay recommend 24lb injectors while summit recommends 30lb injectors, that is my question, which ones should I go with as far as injectors, throttlebody size and fuel pump size?
Trick Flow was also the only one that stated the 350/370 hp/tq was obtained with a 9.5 to 1 306.
I am kind of leaning towards a 76mm maf, 24lb.hr injectors, 75mm throttlebody/EGR spacer and the 255lph fuel pump, just want to see what some of you recommend as I bet some of you have the trickflow kit, and I don't plan on any other mods in the future either. Thanks for any help
