Tricks for setting TPS voltage?
  • Thread starter Thread starter Bill Cool
  • Start date Start date Jul 28, 2010
Bill Cool
Previously 87MustangGT
1,268
Seymour, CT
Jul 28, 2010
  • Jul 28, 2010
I used to be pretty good at (re)setting my TPS whenever necessary... Apparently letting the car sit for 5 years either made me very rusty, or there's actually something wrong with my TPS. Either way, I can't get my TPS to set right.
For about two weeks, I couldn't get it any higher than 0.08v. I tried for the first time in about 2 weeks, and I was able to get it up to .7-.9! But the sensor was tweaked so much that the holes on it weren't lined up with the holes on the TB. So I moved it back slowly, and now the most I can get (when the bolt holes line up) is 0.20v.
Any tips/tricks for setting this bad boy? The holes are already elongated, but I imagine I could drill them out a bit more.
TIA
CDQICKGT
229
fort hood, tx
Jul 28, 2010
  • Jul 28, 2010
TIA
Most of us have to drill them some. You sure your throttle adjustment screw is not out of range. That will cause the throttle blade shaft to tunr and could be your issue.
Bill Cool
1,268
Seymour, CT
Jul 28, 2010
  • Jul 28, 2010
Mine's already drilled, but as I mentioned, there's probably enough meat to drill it out a bit more... In any case, I'm not sure the idle screw isn't out of range. Though idk how it would've moved while parked, I'll def try to tweak it a bit while measuring the voltage tomorrow.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 28, 2010
  • Jul 28, 2010
Setting the TPS: you'll need a good Digital Voltmeter (DVM) to do the job. Set the TPS voltage at .5- 1.1 range. Because of the variables involved with the tolerances of both computer and DVM, I would shoot for somewhere between .6 and 1.0 volts. Unless you have a Fluke or other high grade DVM, the second digit past the decimal point on cheap DVM’s is probably fantasy.
Since the computer zeros out the TPS voltage every time it powers up, playing with the settings isn't an effective aid to performance or drivability. The main purpose of checking the TPS is to make sure it isn't way out of range and causing problems.
Wire colors & functions:
Orange/white = 5 volt VREF from the computer
Dark Green/lt green = TPS output to computer
Black/white = Signal ground from computer
The Orange/White wire is the VREF 5 volts from the computer. You use the Dark Green/Lt green wire (TPS signal) and the Black/White wire (TPS ground) to set the TPS. Use a pair of safety pins to probe the TPS connector from the rear of the connector. You may find it a little difficult to make a good connection, but keep trying. Put the safety pins in the Dark Green/Lt green wire and Black/White wire. Make sure the ignition switch is in the Run position but the engine isn't running.
When you installed the sensor make sure you place it on the peg right and then tighten it down properly. Loosen the back screw a tiny bit so the sensor can pivot and loosen the front screw enough so you can move it just a little in very small increments. I wouldn’t try to adjust it using marks.
A.) Always adjust the TPS and Idle with the engine at operating temp. Dive it around for a bit if you can and get it nice and warm.
B.) When you probe the leads of the TPS, do not use an engine ground, put the ground probe into the lead of the TPS. You should be connecting both meter probes to the TPS and not one to the TPS and the other to ground.
C.) Always reset the computer whenever you adjust the TPS or clean/change any sensors. I just pull the battery lead for 10 minutes.
D.) The key is to check the TPS voltage whenever the idle screw is changed.
TPS testing:
Most of the time a failed TPS will set code 23 or 63, but not always. Use either an analog meter or a DVM with an analog bar graph and connect the leads as instructed above. Turn the ignition switch to the Run position, but do not start the engine. Note the voltage with the throttle closed. Slowly open the throttle and watch the voltage increase smoothly, slowly close the throttle and watch the voltage decrease smoothly. If the voltage jumps around and isn’t smooth, the TPS has some worn places in the resistor element. When the throttle is closed, make sure that the voltage is the same as what it was when you started. If it varies more than 10%, the TPS is suspect of being worn in the idle range of its travel.
TPS Troubleshooting:
The TPS sensor is a variable resistor like the volume control on most cheap radios. We have all heard them make scratchy noises as you turn them up or down. The carbon element can wear and cause a drop out spot in the output voltage. This confuses the computer because it expects to see a steady TPS voltage increase as the Throttle opens up.
TPS troubleshooting steps:
1.) Use the Orange/white & Black white wires to verify the TPS has the correct 5 volts source from the computer.
Use the Dark Green/lt green & Black/white wires to set the TPS base voltage. Setting the TPS: you'll need a good Digital Voltmeter (DVM) to do the job. Set the TPS voltage at .5- 1.1 range. Because of the variables involved with the tolerances of both computer and DVM, I would shoot for somewhere between .6 and 1.0 volts. Unless you have a Fluke or other high grade DVM, the second digit past the decimal point on cheap DVM’s is probably fantasy. Since the computer zeros out the TPS voltage every time it powers up, playing with the settings isn't an effective aid to performance or drivability. The main purpose of checking the TPS is to make sure it isn't way out of range and causing problems.
2.) Use an analog voltmeter to check the voltage on the Dark Green/lt green & Black/white wires to make sure that it increases smoothly and doesn’t drop out or increase suddenly.
Some basic checks you can make to be sure that the sensor is getting power & ground:
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter.
Check the resistance between the black/white wire on the MAP/BARO sensor and then the black/white wire on the EGR and the same wire on the TPS. It should be less than 1 ohm. Next check the resistance between the black/white wire and the negative battery cable. It should be less than 1.5 ohm.
The following power on check requires you to turn the ignition switch to the Run position.
Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts at the orange/white wire on the TPS or EGR sensors. Use the black/white wire for the ground for the DVM.
H
Haus
408
  • Jul 28, 2010
I would just stick the TPS on top of the TB. Make sure the shaft is in a spot to turn the TPS. put your screws in and screw them on but dont tighten them yet.
Clock the tps to get your voltage, when you do, make sure you hold it tightly while you tighten the screws.
that way the screws are already in when you adjust it.
and recheck when the TPS is on completely
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jul 29, 2010
  • Jul 29, 2010
Time to replace it. Its has slowly been deteriorating, and slotting the holes was just bandaiding the issue.
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,079
224
Massachusetts
Jul 29, 2010
  • Jul 29, 2010
Anywhere between 0.5 - 1.1 volt is good. No need to chase the 0.99 number. Upon startup, the car takes idle voltage and adds 3.5 v and sets that as wot voltage.
If you mess with the tps with the car running, it changes fuel and timing, so the car will run different, but as soon as you shut it off...all your hard work is undone and the car resets it's idle baseline.
So 0.8 is good. Anything outside .5 - 1.1 sets off a code 63
Bill Cool
1,268
Seymour, CT
Jul 29, 2010
  • Jul 29, 2010
Except that's what 97% of StangNet has to do to set their TPS correctly. Advice if I've already tried a new TPS and it also doesn't go above 0.08v or so?
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,079
224
Massachusetts
Jul 29, 2010
  • Jul 29, 2010
You aren't supposed to go above. If you bolt it on at 0.8 you are good. It doesn't matter if it's 0.8 or 0.99... The car takes either as a base voltage on startup and adds 3.5 or so.
Slotting the tps and searching for 0.99 is a myth. The tps is essentially non adjustable on these cars. Somebody one day long ago twisted a tps on a running car around and found it ran better as you went higher. That is because then car thinks you are giving it gas. When you turn the car off, that adjustment is lost. In otherword say you start the car at 0.6 volts and twist the tps ip to 0.99. The car thinks you are now .39 volts above idle and adds fuel and timing. When you turn the car off and restart, it resets baseline. Now 0.99 volts is baseline and the car gives fuel and timing for idle. To mimic the same 0.39 volts over idle...you would need to now twist the tps to 1.38 volts. Get it? As log as if you bolt it on and it's somewhere between 0.5 and 1.1 you are all set.
Bill Cool
1,268
Seymour, CT
Jul 29, 2010
#10
  • Jul 29, 2010
  • #10
0.08v
H
Haus
408
#11
  • Jul 29, 2010
  • #11
then you got wiring issues if this also happened on a new TPS or you are doing something wrong
L
Lawbreaker5.0
543
Texas
Jul 29, 2010
#12
  • Jul 29, 2010
  • #12
I had mine at .6x and I would let off the gas to coast then press the pedal and nothing would happen. Then all of a sudden it would kick in. It was a good sec pause. I elongated the holes to get to .9x and the car stopped doing it. Maybe it was something else but that was my experience with the TPS.
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,079
224
Massachusetts
Jul 29, 2010
#13
  • Jul 29, 2010
  • #13
87MustangGT said:
0.08v
Lol. I'm going on 3 days with 6 hours of sleep total.....
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jul 29, 2010
#14
  • Jul 29, 2010
  • #14
If this is a new TPS, then its time to check the reference voltage between the orange and black wires. That should show 5v. JR has pretty much outlined that. Also, since you are checking voltages using the black wire as ground, try using a body ground. If your voltage now shows a none failure code voltage, then the issue is within the ground circuit. That's assuming you have the 5v previously mentioned. If the 5v is absent, then its time to go over the 10 pin connectors as all the circuits for the TPS passes through them.
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,079
224
Massachusetts
Jul 30, 2010
#15
  • Jul 30, 2010
  • #15
Are younturning the key to on as well?
Bill Cool
1,268
Seymour, CT
Aug 12, 2010
#16
  • Aug 12, 2010
  • #16
yes
I've already done the VREF test, and got 5.08-5.09v with the black wire and a body ground.
94 TB & TPS with 89 A9L - can't get 0.98v
  • Wallyman
  • Jun 11, 2024
  • Other Auto Tech
Other Auto Tech Jun 15, 2024
CAMTWO1070
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
