trim for 92 vert
You could just paint if flat black if you want to freshen it up.
You could go to www.50resto.com if you want to buy new.
The front windshield trim there are many philips screws that you must remove. I would highly suggest not to remove the weatherstrip seal that runs along the right and left windshield frame that seals to your door glass. It must be removed to get the philips that are behind there, but you will tear it taking it out because Ford used some glue in there. Out of all the conv in my yard, I think I managed to get one out without ripping it. You can buy the seal new, but it is expensive, and it looks really really cheesy. Does not look like the OEM one.....hope this helps.
I pulled all the windshield trim off the car when I painted it. I was lucky and was able to get the weatherstrip off with out shredding it. The lower trim clips onto the car. You have to gently pry it up a little and then you can pull if off the car. The cowl grill will have to come off first though.
Have you priced the convertible top trim yet? If not when you see how much they cost you will definitely want to paint all the trim instead of replacing it.
well the right side will have to be replaced im guessing somone locked the keys in it the weatherstiping is trashed and the molding is dented pretty bad may get by with those to pieces and paint the rest thanks for the help
