Trouble code question?
  • Thread starter Thread starter Shauns GT
  • Start date Start date Aug 28, 2004
Shauns GT
101
Brandon, Manitoba, Canada
Aug 28, 2004
  • Aug 28, 2004
Can anyone tell me what a KOER 42 means?
HISSIN50
34
129
Aug 28, 2004
  • Aug 28, 2004
i think it is a code for being rich - no O2 fluctuation. was the motor fully warm when you ran the test?
good luck.
Shauns GT
101
Aug 28, 2004
  • Aug 28, 2004
Yes the motor was quite warm i had just been crisin around town. I just fixed a leaking injector problem and installed a new Coolant Temp sensor last night. It seemed to be running not too bad but then it started stalling out again.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 28, 2004
  • Aug 28, 2004
KEOR 42 - "HEGO (HO2S*) circuit indicates system rich (right HO2S)"
The right side O2 sensor is sensing rich conditions beyond the range of the computer to adapt and fix it with the adaptive strategies of the computer.
Shauns GT
101
Aug 28, 2004
  • Aug 28, 2004
That figures i tried changing my 02 sensors earlier this week but i got bosch ones and they were a lot bigger then the ford ones and the right hand side sensor got jammed between the K member and the H pipe and it made the whole car vibrate like crazy when i tried to drive it. So i swaped the old ford one back in. Has anyone else come across this before? Is Ford still producing Theses skinny, smaller sensors?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 28, 2004
  • Aug 28, 2004
I just bought 2 Bosch sensors from AutoZone for mine - they were just like the ones that came out. Is it possible you damaged the wiring harness when it was touching? The code says it could be the "circuit" as well - perhaps you simply have a damaged wire(s).
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
