Trouble Codes 41 and 91 miss
  • Thread starter Thread starter sphugh1967
  • Start date Start date Jun 26, 2005
sphugh1967
17
  • Jun 26, 2005
I have a miss at high rpm sometimes in my 1991 mustang. With the engine running I pull these two codes 41 and 91. "o2 Sensor voltage low sensor lean" my fuel consumption seems to be high and the car just isn't running right. I have replaced the o2 sensors that didnt help. Does anyone out there have any idea what this could be. I tuned the car up (plugs, cap, wires, rotor, I have tested the coil and the ignition module both check out. Could the stock fuel pressure regulator be bad? I have also replaced the fuel pump with a 190lph FRPP model and I replaced the filter at the same time. Any help here is appreciated. Thanks
HISSIN50
34
129
Jun 26, 2005
  • Jun 26, 2005
If the miss occurs at WOT, that suggests that it is not the O2's anyhow (it was a good idea to replace them though, from the sound of it).
I would look for a vac leak for that code.
It could be something as simple as two plugs wires sitting next to eachother, and at high RPMs they misfire (it happens).
Good luck.
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • Gulftown980x
  • Jul 29, 2026
squeak93
