Trouble starting after Kennebell Install
goshia
252
Mead, Colorado
I have finished my install but the car won't start.
The starter is doing everything it can but it just won't fire up?
I sanded the connector for the chip real well... No dashes on the odometer. intercooler pump working properly. No Leaks any where.
please read the instructions carefully,those two wires go to the boost switch which must be hooked up(raises fuel pump voltage to 17 under boost).if you did not know what these were for, there is a good chance you wired it wrong.do you hear the fuel pump run for about 2 secs after you turn key on?
