  • Mustang Sound & Shine All
Trunk Ideas
  • Thread starter Thread starter zincyellow03
  • Start date Start date May 20, 2005
zincyellow03
My dead ho likes Chicago
May 20, 2005
  • May 20, 2005
Today, I built my box for my sub. I was going to add the amp into the box with the sub but, I went against it because the amp needs to breathe so I won't over heat. Now I don't know where to put the amp in my car, but I don't want to put it in my area where my spare tire is. Also, I would want to have as much trunk space as possible. Anyone have any ideas? Pictures would help.
Thanks
PS: My box is 18 x 14 x 14 (L x W x D)
Infinity
956
Charlestown, IN
May 21, 2005
  • May 21, 2005
How much space is there between your rear deck and the enclosure? I used a trick I got from Volkswagen and hung the amps in a "cage" off the rear deck. If you don't have the Mach shelf in there, there is all kinds of space for them to breathe. I have also simply turned amps upside down and mounted them on rear decks, but I don't recommend it as heat would then rise through the amps circuit board instead of through the intended heatsinks. BUT, I've never had one go bad hanging it upside down, it's just that the possibility is there.
semperfistang
47
  • May 21, 2005
try on the back of the back seats. i have one on each seat.
Jake
zincyellow03
May 21, 2005
  • May 21, 2005
If I put it on the back of the seat, won't it affect the amp since it's cloth?
Infinity
956
Charlestown, IN
May 22, 2005
  • May 22, 2005
nope
zincyellow03
May 22, 2005
  • May 22, 2005
The box is already built, I decided to attack the amp to the side of the box. The system is almost in, I just need to finish some wiring...
I'll try to post some pics of the box when I can.
Infinity
956
Charlestown, IN
May 23, 2005
  • May 23, 2005
While that works, I like to attach the parts seperately so a thief has to actually spend some time to remove my ****. No grabbing a box and making off with extra stuff. The amp may also fit under the passenger seat- but it's unlikely.
zincyellow03
May 23, 2005
  • May 23, 2005
Good point, but in my case, the box doesn't fit and now that it fits in the trunk it's really hard to take out. You have to first take the spare out and move the carpeting and then slide the box into the empty space and left...hmmm... maybe I shouldn't have said that now someone can steal it from me
nhra427
169
Oregon
May 24, 2005
  • May 24, 2005
I have heard to stay away from mounting amps on sub boxes because of vibrations. dont know if thats true.
Infinity
956
Charlestown, IN
May 24, 2005
#10
  • May 24, 2005
  • #10
If your box vibrates, then it is built improperly.
My wife's box got vibrated once, and she blew my tweeters!
W
Willy0314
178
Western Ny
May 26, 2005
#11
  • May 26, 2005
  • #11
strokedandblown
Banned
May 3, 2005
555
USA
May 27, 2005
#12
  • May 27, 2005
  • #12
There is no problem mounting a amp to a box. You just need to stay away from directly mounting it to metal, This will cause a ground loop and you will pick up frequency noise in the music.
ive got 6 subs running in my suv @ 1.3 ohm and the amps are mounted upside down and in there own enclosure and i dont overheat. You just have to test it out The amp will never blow it will go into protection mode till it cools enough.
Im sorry about you wifes vibrating box, You might want to get that checked out!
Infinity
956
Charlestown, IN
May 27, 2005
#13
  • May 27, 2005
  • #13
I check, and check, and check some more. She says it isn't a problem
Scott_95GT
387
Sacramento
May 27, 2005
#14
  • May 27, 2005
  • #14
On my old 95 GT, I had a custom box for two 12's, and had the amp mounted on the back of the right backseat. Trunk space was still decent also because the box was built to fit flush against the angle of the backseats.
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
New fuel pump relay
  • Scrapla347
  • Nov 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 8, 2025
Scrapla347
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech May 31, 2026
LILCBRA
M
Inheriting (and likely restoration of) a 1965 Mustang
  • miniwheats235
  • Feb 17, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 19, 2026
Realmongo
