  • 2005 - 2009 Specific Tech
Trunk Opening Problem? Anyone Else?
  • Thread starter Thread starter hottymustang
  • Start date Start date Nov 10, 2005
hottymustang
58
Temecula, CA.
Nov 10, 2005
  • Nov 10, 2005
Hey guys! My trunk will not pop on its own. When I push the button on the remote it will release the lock, but I have to manually pull on the trunk lid to open it. It started doing this about a month after I got the car. I never hit the lock area right there with anything to damage it in any way.
Has anyone else had this issue before? I am taking it into the dealer Monday for some other warranty work also, so I will give you an update.
Thanks guys!
:SNSign:
crewwolfy
108
Chicago, IL
Nov 10, 2005
  • Nov 10, 2005
Can't say I have. Check the lining where the trunk meets the lid. Check and see if anything's jamming up the lock mechanism, though I doubt it.
GOLDENPONY
1,503
LOVELAND, OHIO
Nov 10, 2005
  • Nov 10, 2005
Trunk
My '06 has never opened by itself. I push the button, the lock releases and I have to lift the lid. Is it supposed to open by itself?
hottymustang
58
Temecula, CA.
Nov 10, 2005
  • Nov 10, 2005
Yes it is supposed to open by itself. I wouldn't think that Ford would changed that between the 05 to 06 model years, that would be a little goober.
PolkThug
130
Somewhere voiding my warranty!
Nov 10, 2005
  • Nov 10, 2005
My '06 has to be lifted manually and I think I prefer it that way.
stanmckinney
1,188
Nov 10, 2005
  • Nov 10, 2005
Open how much by itself? Mine may open an inch or so but that's it. Is it supposed to go up more than that? I also think I prefer having to open it fully myself.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Nov 10, 2005
  • Nov 10, 2005
no, cars are designed to only open a little bit. cars that open all the way need adjustment.....(or none at all)
Humboldt Stang
64
  • Nov 10, 2005
The only problem I've had with the trunk is that little button on the remote is waaaaay too easy to accidently press.
I don't know how many times it's popped the trunk unintended.
Z
zeindog
66
  • Nov 10, 2005
I have the same problem on mine, the weatherstripping is sticky and holds the trunk from releasing. I put some armour-all on the weatherstripping and it kept it from sticking.
hottymustang
58
Temecula, CA.
Nov 10, 2005
#10
  • Nov 10, 2005
  • #10
I will try that thanks. But before, it would pop open a inch or two when I hit the button. So I would just have to push it up, but now it doesn't pop at all and I have to really pull on it to get it open.
Thanks for all your help guys!
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
Foxbody Keyless Entry Help
  • sawan
  • Apr 2, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2024
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
