I have read where all the manufacturers say their CAI systems are worth 20 horse power at the rear wheels and others say they are not worth the money. Any truth to either myth?
tomustang said:I've heard Velocity Donuts work
Miles said:Pretty much every mod that comes to mind is better than a CAI - look at my long list, notice I haven't even bother yet? Save the cash![]()
RoadconeTuning said:im not saying that i picked up 50hp but i would say a good 10hp was felt close to redline...
[Twitch] said:So i just received my K&N intake and I decide to do a couple of test and datalogs.
Temperature today was 55.4F and the two test were done without one hour of each other. The car used is a 2001 Mustang GT. The stock intake used had the silencer removed.
I did a idle log just to see what the intake temperatures are like. Engine coolant temperatures were the same.
STOCK
IAT MAX : 92F
IAT MIN : 86F
IAT AV : 89.42722266F
ECT MAX : 202F
ECT MIN : 190F
ECT AV : 195.1125098F
MAF MAX : 522GM/S
MAF MIN : 427GM/S
MAF AV : 468.1471282GM/S
K&N FIPK
IAT MAX : 112F
IAT MIN : 90F
IAT AV : 102.4705F
ECT MAX : 202F
ECT MIN : 190F
ECT AV : 195.8300551F
MAF MAX : 565GM/S
MAF MIN : 443GM/S
MAF AV : 489.9677419GM/S
As you can see, the IAT for the K&N is higher than the stock one for obvious reasons. The K&N is fully exposed to the engine compartement as oppsed to the stock one which has a casing around the whole filter. So when the car is not moving, K&N will have a higher IAT.
Also, MAF reading for the K&N are a more than stock(better hope so).
Here's a graph of both runs at idle for 120 seconds
The next run is a 1 mile higway run from one exit to another. I tried to keep the same speed and driving habits so the data can be relevant.
STOCK
IAT MAX : 110F
IAT MIN : 84F
IAT AV : 91.99381F
ECT MAX : 196F
ECT MIN : 190F
ECT AV : 191.8602F
MAF MAX : 19 910GM/S
MAF MIN : 538GM/S
MAF AV : 2376.385GM/S
K&N FIPK
IAT MAX : 104F
IAT MIN : 68F
IAT AV : 73.77699F
ECT MAX : 202F
ECT MIN : 188F
ECT AV : 191.5991F
MAF MAX : 20 707M/S
MAF MIN : 485GM/S
MAF AV : 2511.444GM/S
Right away you see a differene of 18F in average IATs. Since the K&N filter is more exposed, air flowing through the engine bay can be sucked in by the K&N filter. The stock filter being enclosed in a plastic shell, can only suck air from a small area, close to the fender. With K&N you can get IAT as low as 68F. So, once the car is moving, K&N IAT will dramatically drop and will ahve cooler charge than stock even though it's not a cold air intake kit, jsut the fact it can be in contact with the air outside flowing through the engine bay can reduce IAT.
Here's a graph of both runs. You can see those two fine curves, those are the VSS of both runs, in MPH, so you can see the speed are very close to each other in both runs.
I've got more data but Í'm just too tired to look at it. I hope you guys frind thios useful.
