Trying to help a friend, Need Advice
NOTCH_GUY
31
N.E. PHILLY
Hi, all.
My friend has a 89 Stang project that pops during lite acceleration. When it happens you can stab the throttle and it takes off like a bat out off hell with no other apparent issues. It happens at all temps. I've gone over everything 2-3 times over and I'm stumped.
About the car: 87 Gt engine, cobra intake w/1" spacer, 1.7 roller rockers, 80mm Pro-m, 75mm T.B., PowerDyne supercharger(8-9psi), walbro 255 lph pump, msd pro billet dist, 6al, tci c4. Every sensor in the car is brand new. I just can't seem to figure this out. Any help would greatly appreciated... Thank you..
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Ignition timing is set @ 10deg. base. I did pull codes with a Snap-On Scanner a little while ago. I honestly don't recall all the code numbers, but the only codes that were present were for smog equipment which has been completely removed. This is why I feel stuck at this this point. For some reason I keep returning to the fuel system but I can't put my finger on it. Fuel pressure is at 40-psi with good volume. The car doesn't miss a beat except on initial acceleration. It almost feels like the TPS but I scoped it with a Vantage and it sweeps clean from closed to full throttle.
Thanks..
