TSB or Owners Manual fluid level for 3650?
What Fluid Level for 3650 Tranny?
  • TSB Revised Fluid Level
    Votes: 7 100.0%
  • Owners Manual Fluid Level
    Votes: 0 0.0%
  • Total voters
Blue70
160
28
38
Wilmington NC
I just ordered a new shifter and it should be here Wed.
I will be changing the tranny fluid at the same time.
The dealer said synthetic would help the cold 1-2 shifts.
Should I go with the level in Fords TSB (3.8 qts)
or with the Owners Manual (fill it till it comes out the hole)
Did the TSB level help anyones 1-2 shift when the tranny is cold?
The tranny will hold well over 4 quarts if you fill it until it comes out the hole. That is way too much fluid. Do the revised level and be done with it, pour the new fluid through the shifter base while it's off, makes it real easy.
If it's in the 20's or low 30's it will feel a bit notchy going into 2nd, but no grinding.
I took it to the dealer and they said it was normal, but of course the night I left it there it was only in the 40's...Of course it had been in the 20's for 3 days in a row before that. They said to throw some synthetic in it.
