Tubular K-member and coilovers
For drag, assuming a nearly stock weight car, for front coil-overs look for about 175#/in springs.
QA1 parts are junk. We had their full front set-up on a car and after 1 month the c/c plates were destroyed, the springs hit the fenderwells and the strut bodies, the headers had to be dimpled to clear the steering shaft since the K-member moves the rack for no reason, which also caused an over extension of the shaft which caused it to be replaced.
If you plan on constant trips above 100moh, this isn't the set-up you want.
For a drag only car, I'd go with AJE or PA which have good lightweight strong set-ups.
Don't buy a used AJE k-member though, as there were some recent changes to add strength that the older units don't have.
