  • 1994 - 1995 Specific Tech
Tune by Chip
  • Thread starter Thread starter final5-0
  • Start date Start date Feb 2, 2007
1 of 2 Next Last
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 2, 2007
  • Feb 2, 2007
I would like a few replies to a couple of simple Questions
What was the approximate price range you paid for a mail order chip?
How about an off the shelf chip?
Thanks Everybody
Grady
parchisi
519
New Mexico
Feb 2, 2007
  • Feb 2, 2007
it was a little while ago, but I think I recall around $400 for a mail order tuned chip from JMS.
gcomfx.com
3,690
Republic, MO
Feb 2, 2007
  • Feb 2, 2007
http://www.lasotaracing.com/mailorder.html
Yobi1Kanobi
559
  • Feb 2, 2007
i got a custom diablo for about 400 or so
1slow95
1,797
ohio
Feb 2, 2007
  • Feb 2, 2007
$250 for the SCT chip and I think $150 for the dyno tune. Had about another $50 or so in taxes too.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Feb 2, 2007
  • Feb 2, 2007
i forget what i paid for a used SCT chip, little over 100
then 160? for 2 hours of tuning time
drakesdad
961
Oregon OHIO
Feb 2, 2007
  • Feb 2, 2007
400/500 which included a thorough inspection and dyno time......and some adjustments I requested
95opal
5 Year Member
Nov 16, 2004
449
20
39
Feb 2, 2007
  • Feb 2, 2007
Not to side track the thread but what MAf are you guys running and how good was the tune you recieved with the chip if it was mail ordered? The reason Im asking is Im getting ready to drop in my new combo and i alreay have 30# injectors so I need to decide on a MAf, Ive also decided to go with a SCT chip I just dont know how Im going to approach this. thanks
gcomfx.com
3,690
Republic, MO
Feb 2, 2007
  • Feb 2, 2007
Talk to Don at Lastoracing. He recommended the cheapest route, which was the 42lb. injectors and Lightning M/A meter. He said he would tune the chip accordingly.
4Jenna
4,326
AZ
Feb 2, 2007
#10
  • Feb 2, 2007
  • #10
450$ for chip and dyno tune
95opal
5 Year Member
Nov 16, 2004
449
20
39
Feb 2, 2007
#11
  • Feb 2, 2007
  • #11
I had planned on speaking with him but as you said he recommends the 42#s and I already have 30#s and dont want to spend more $ injectors, as I went overboard already on this. Well I guess i should speak with him first before I do anything anyway. thanks
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 2, 2007
#12
  • Feb 2, 2007
  • #12
Great info so far guys
and
I thank you for sharing
My main interest at this point is focused around mail order
Feel free to post up any info however
Grady
drakesdad
961
Oregon OHIO
Feb 2, 2007
#13
  • Feb 2, 2007
  • #13
Mine was not mail...I took it to Don.......who trains people on installing the SCT chip........he may be able to recommend someone on the East Coast......I run a 75mm Granitelli with 24's.....
95opal
5 Year Member
Nov 16, 2004
449
20
39
Feb 2, 2007
#14
  • Feb 2, 2007
  • #14
I see you run a ganitelli w/ your set up. Is that MAF recald to the injectors or was that all taken care of w/ the chip? What it really boils down to for me is will I need a start up tune or will i be able to drive it to the dyno for a tune? Now if I go with a Ligthning MAf or SCt meter I will most definately need the start up tune. But if I go Pro-M then i can probably drive it to the dyno at least im hoping this would be possible. But is it the right way to go? Whats better for tuning purposes a recald metter or one like the lighting? Sorry gady for the sidetrack but it seems to me that the MAF is a key player in the tune and chip. any input would be great
D
drewzx3
411
Louisiana
Feb 2, 2007
#15
  • Feb 2, 2007
  • #15
I 2nd that I dont remember how much mine was exactly but it was alot less than $400
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 2, 2007
#16
  • Feb 2, 2007
  • #16
No prob as you are looking for basic understanding here
I'll hit the high points
and
if you want all the details ... look on my site
A maf IS about airflow ... NOT ... about fuel inj size
When we mod our Stangs .........
Our need of more fuel (larger inj's) presents itself
way before
Our need of a meter that can report more airflow to the pcm
Where most get confused is ...........
the maf manufacturers devised that ....... "Cheat Method"
as a way for using larger inj's without a custom tune
Most just naturally think all meters are called for a certain
size inj
anyway .........
It worked Kinda Sorta OK with the Fox Stangs
but
Its a bit Sucky with our Stangs
Any method of tuning which gives access to the maf transfer and
inj size values in the pcm will be more accurate than that "Cheat Method"
which is based upon falsely reporting values to the pcm.
When one can understand this info here about .............
how the inj's and maf work together .............
You see your Stang in a whole different light
and
You see the differences between it and the older Fox Stangs
This maf/inj stuff took me a while to get my head around it
but
Since our cars are load based
and
the maf is used to determine that load
You wanna be as accurate as possible in this area
Clear as mud
Grady
drakesdad
961
Oregon OHIO
Feb 2, 2007
#17
  • Feb 2, 2007
  • #17
I bought the MAF that was already set up for 24's......i drove mine for quite awhile before the tune..........it def. helped with a lot of the driveability issues......I bought the 24's first and then searched for a MAF..
95opal
5 Year Member
Nov 16, 2004
449
20
39
Feb 2, 2007
#18
  • Feb 2, 2007
  • #18
Well Grady maybe you can help me with this one. My new set up consists of AFR 165s, FTI cam, TFS intake and the 30#s. The problem is im stuck w/ this C&L 76mm MAF that came on the car and ther is no way im going to use it with the new set up. So would you (A) get an 80mm Pro-m (B) lightining MAF (C) find a Stock MAF. Mind you, i will definately be getting it dynotuned and a chip burnt. Thats where the second problem comes in the dyno is a good hour from me so I would like to be able to drive it there without to much of a headach. Your imput is much appreciated
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 2, 2007
#19
  • Feb 2, 2007
  • #19
The stock maf is not an option for you here
You will be at or very close to its airflow limit with your combo.
At one time ... I did not care all that much for the C&L meters
however
More and more peeps have had good results with them
but
I do wanna point out ... these are peeps who custom tune them
You of course would wanna use the 30 tube if you try the C&L
You could use a Lightning maf
or
ProM 80 would be fine as well
If you go ProM 80 ... you would want to get it caled for 30's
In the ProM line ... I'd go with the 77 or 80 before the 75 bullet
As for the drive to the shop to get it tuned .....
I don't see how you would make it with a L meter & 30's
Does any of this help you
Grady
95opal
5 Year Member
Nov 16, 2004
449
20
39
Feb 3, 2007
#20
  • Feb 3, 2007
  • #20
Grady thanks for the info. I was leaning towards the 80 Pro-m for the simple reason of getting the car to the dyno under its own power.
1 of 2 Next Last
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Digital Tuning Chip tuning in 2025, what are my options?
  • AnthonyA1234
  • Feb 3, 2025
  • 2 3
5K
Fox 5.0 Mustang Tech Jun 17, 2025
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
