Tune Removal
  • Thread starter Thread starter Wolf-Mxbee
  • Start date Start date Nov 11, 2017
W
Wolf-Mxbee
  • Nov 11, 2017
My 05’ Mustang V6 may have a possible SCT tune on it and would like to know if I can remove it? First it had a sct tune emblem stuck on the dash “yuck” and two, the car is telling me that I am only getting 10.1 mpg and when I have a little fun it gets down to around 8 or even 7, three the car is really jumpy when I barely touch the pedal, already goes from around 1200 up to 3000 for example
Svtpilot
944
59
59
Long Island, NY
Nov 12, 2017
  • Nov 12, 2017
Typically when a car is tuned, the factory tune is saved on the tuner, so it can be reloaded if needed . I am assuming that a hand held tuner was not included with the car when you bought it. If by chance it was, then it should have the factory tune saved on it an it should be pretty simple to reload it. Otherwise a Ford dealer should be able to reflash the pcm and restore the factory tune. However, and this is important, before you reload the stock tune you have to make sure that there are no other mods done to the car that require a tune. For example does the car have an aftermarket cold air intake? Most aftermarket CAIs require a tune. If you have one that does and you reload the factory tune, the car will run lean which can lead to internal engine damage. So check the car over carefully see exactly what you have as far as aftermarket parts if any and go from there.
It also sounds like the gears may have been changed as well , I would check
W
Wolf-Mxbee
  • Nov 12, 2017
Alright thanks! I will definitely give my car a close look at and it didn’t come with a tuner sadly, today I went to back out of my driveway and put it in gear and I pressed down on the gas and the car wouldn’t move, it revved high then took off
Svtpilot
944
59
59
Long Island, NY
Nov 15, 2017
  • Nov 15, 2017
That sounds like a transmission issue.
W
Wolf-Mxbee
  • Nov 18, 2017
Yea I noticed when putting my car into gear, it sometimes has resistance like when putting it into reverse, it sometimes act as if I don’t have my foot on the brake and won’t move so I had to jiggle it and it works, how much would it be to get a auto transmission maintenanced or serviced?
W
Wolf-Mxbee
  • Nov 18, 2017
E
Nightmare after tune install!
  • EnemyofTyranny
  • Mar 29, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 12, 2025
89ripper
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • dan50
  • Jul 18, 2026
dan50
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
