Tune Up Questions
  • Thread starter Thread starter shlby123
  • Start date Start date Mar 9, 2006
shlby123
579
Dallas
Mar 9, 2006
  • Mar 9, 2006
Hey fellas, Im looking to tune up the 89 5.0 I just got, and I dont know where to start AT ALL. I want to do as much as I possibly can myself. I've only done a simple oil change so far (the easiest part) and my key objective is inexpensive but high quality parts...All i have is exhaust and a pro 5.0 stick for mods....so nothing fancy yet. please help.
sunil6784
620
Boston, MA
Mar 9, 2006
  • Mar 9, 2006
My tune up list:
Oil change w/ filter
Spark plugs (autolite 25s)
Wires if necessary
Distributor cap and rotor
Fuel filter
Air filter (or clean if you have a k&n)
CHange the coolant if necessary
O2 sensors if necessary
Also, if you really feel like it, or if the time has come, you could also change the tranny fluid and rear end fluid.
shlby123
579
Dallas
Mar 9, 2006
  • Mar 9, 2006
Any recommendations on plugs & wires? What is the difficulty of doing it myself? Any step by step info on how to do it?
Tonys96Cobra
professional deer "mounter"
Oct 28, 2005
29
Syracuse
Mar 9, 2006
  • Mar 9, 2006
WHen I do plugs and wires, I alway get a set of 8mm's from checker, yeah I know they prolly arent the best) because they carry the lifetime warranty, even if you pull one apart on accident. As far a s a step by step, just do them one at a time, that way you cant mess up the firing order. Pull 1 wire and plug, gap the plug, install it. Choose the new wire that is closest in length the old one, pu it on, move to the next one, its that simple. And remove the airbox silencer from the inner fenderwell and put in a K&N.
vristang
4,933
101
124
Seattle
Mar 9, 2006
  • Mar 9, 2006
Even if I am not having any issues I like to pull the computer codes everytime I change the oil.
But I do weird things all the time.
Not mentioned is inspection/replacement of pcv
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Mar 9, 2006
  • Mar 9, 2006
The MOD list w/ Tune up recommendations
If it's stock and you are looking for a place to start, you can choose to follow this list. I complied this with the help of Stangnet (Go STANGNET!).
First mods should be as follows (my take):
In order of Priority
1) Subframe connectors (SFC's) full length ones are prefered for a stiff chasis
2) Gears: 3.73:1 or 4.10:1 seem to be the popular choices
3) Full Exhuast (headers, hi-flo cats, catback w/ mufflers)
4) Buy a K&N panel filter (no CAI kit required) and put it in the stock box
5) Bumped timing to 12 - 14 degrees (free mod) 10 Degrees is stock.
6) Larger MAF, TB (MAF cars from 1988 california only, 1989-1993)
7) 3G alternator upgrade / electric fan
8) Fix the weak brakes
Optional MODs:
9) Strut tower brace (necessary on Convertibles IMO)
10) Underdrive pullies (they can't be used on S/C motors and cause charging problems)
11) Weight reduction out of the nose of the car
12) Shocks/Struts and lowering springs
13) C/C plates if you lower the car
14) Short throw shifter (if you have a manual transmission)
After those (the basics), it's pretty much up to you. There are plenty of Super Chargers or Heads, Cam and Intake packages to choose from.
Also, don't forget about the basic tune up
1) Changing all of the fluids (oil, coolant, trans, rear end, brake and some of the power steering)
2) Plugs: (non-platnum type) Autolite or Motorcraft are prefered
3) Oil filter: Motorcraft or equivalent (not FRAM)
4) Air filter: see first mods item #4
5) Plug wires: Ford Motorsport (FRPP) 9mm units are great
6) Cap / Rotor
7) Oxygen sensors
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Mar 9, 2006
  • Mar 9, 2006
Go ahead and change the IAB and the TPC... no matter what anyone tells you just change the peaces of crap
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Mar 9, 2006
  • Mar 9, 2006
Hoodstrype: I still need to update the list, do you remember what you wanted added? I can't find the post with what you said I was missing (for an optional mod)
shlby123
579
Dallas
Mar 9, 2006
  • Mar 9, 2006
badass! This is a great start guys! The motorsport wires, any particular place I can find those at a low price? And i dont know how to gap plugs but i've heard people talk about it a lot. help?
HISSIN50
34
129
Mar 9, 2006
#10
  • Mar 9, 2006
  • #10
I agree with the ignition tune-up items. The Ford wires should be about 40-45 bucks from many places IIRC. Autolite 25's here too.
Tony, more than one member likes those same wires. I run them on other cars for the reason you do (the wires come apart on the 4 bangers with deep plug wells, so that aspect of returnability is nice. :nice ). Some do like a little flash on the 5.0 motors hence the pretty wires (I run Mallory wires on the fox and MSD Superconductors on the 94).
I like brass point caps (from the parts store is fine with me).
I agree about doing the fluids as you find time.
Just give stuff a once over and see what it needs. Stuff like U-joints, tie rods, brakes etc tend to need addressing.
Good luck.
shlby123
579
Dallas
Mar 10, 2006
#11
  • Mar 10, 2006
  • #11
but how do i get the plugs gapped and all that good stuff?
HISSIN50
34
129
Mar 10, 2006
#12
  • Mar 10, 2006
  • #12
A plug gapper can be had for as little as 99 cents at the parts stores.
I would get some neverseize (in the RTV aisle) and put it on the new plug threads.
Good luck.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Mar 10, 2006
#13
  • Mar 10, 2006
  • #13
Hmmm... I think it was setting the TPS to .099? I dunno if it was luck but my new one is at .098 and has no room for adjustment, so I dunno if the new ones come that way or not
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Mar 10, 2006
#14
  • Mar 10, 2006
  • #14
They usually come pregapped... I think our cars ('89) are 45 thousandths... you do need to check them. Get a Chiltons Manual, and go knock yourself out! That's how I learned
sunil6784
620
Boston, MA
Mar 10, 2006
#15
  • Mar 10, 2006
  • #15
Most people run their gaps around .050
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Mar 10, 2006
#16
  • Mar 10, 2006
  • #16
Yeah- they actually changed in in 90 or 91 to .050 or .055
HISSIN50
34
129
Mar 10, 2006
#17
  • Mar 10, 2006
  • #17
The spec is 0.052" - 0.056".
DONT trust that the plugs are gapped right out of the box. I dont think I have ever gotten any that were right on.
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
W
Megasquirt base tune for 94 5.0
  • wrx757
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2026
wrx757
W
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
