All right , been searching for hour - two and nothing so ... simple question :
Which brand should I choose for spark plugs , rotor and all that ***** for tune up? Car is daily driven with 78.000 miles on it, exhaust and k&n filter, thanks.
You seem to be pretty much stock, Autolite copper plugs, I like the stock cap and rotor from ford, but a bose or similar will be ok, DO NOT CLEAN YOUR K&N unless its caked with dirt, otherwise leave it alone... Most people do not know how to properly clean and reoil them, if you read the K&N directions you will most likly over oil it, and foul the MAF.
Also if you havnt cleaned or replaced the PCV you may want to look into that, This is another piece I buy from ford only. With 78k miles I doubt it's bad, but check it anyway, And finally filters, fuel filter to be exact, I change mine about once a year, again not needed as much as I do it, but i'm weird.
