  • SN95 4.6L Mustang Tech
Tuner Arrived...
  • Thread starter Thread starter kyles03sonicgt
  • Start date Start date Jun 21, 2006
K
kyles03sonicgt
111
Berkley, Michigan
Jun 21, 2006
  • Jun 21, 2006
Hey guys my sct tuner came in the mail today and to install the tune in the directions it says I need to disconnect the fuel pump and the electric fan fuses, is that necessary?? If so, how do i do it??
K
kyles03sonicgt
111
Berkley, Michigan
Jun 21, 2006
  • Jun 21, 2006
Anyone?? Please guys just a guess even if you don't know....I want to go install the tune right now!!!
DeadLifter
183
Portland, IN
Jun 21, 2006
  • Jun 21, 2006
Mine was under the hood in the fuse box. It was a 60 and 20 watt right beside each other. The second ant third from the right in the top row if you're at the front of car facing the windshield, but I have a 97.
I just got one the other day the tunes were crap. Everytime I'd push in the clutch the rpm's would stay where theey were at for about 7 seconds then fall to 1,500 rpms and stay forever. I sent it back the next day (didn't feel like payin for a dyno tune)
Hopefully you'll have better luck.
On mine it said to disconnect the battery after you were done for 30 seconds.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 21, 2006
  • Jun 21, 2006
I did not pull mine. I also ignore the WDS/IDS at work when it says to do the same thing.
The reason they want you to pull them is to prevent the battery from dying durring programming. it is a BIOTCH to get it right again if that happens.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 21, 2006
  • Jun 21, 2006
agreed, if your battery is pretty good you shouldnt have to remove the fuses, but if your worried about it at all just pull em, only takes a sec.
their labeld in your owners manual
propellerhead
1,541
"but what's with the but shots?"
Jun 21, 2006
  • Jun 21, 2006
I remember seeing something on sctflash.com about this. It was mainly intended for the Ford Focus. It takes like 3-4 minutes to flash that car so they prefer you pull the fan fuse so the fan doesn't stay on for the whole 3-4 mins and drain your battery. On Mustangs, we are done in about a minute so it's no big deal. If your battery is halfway decent, it won't die on your during the flash.
loosescrew79
313
  • Jun 21, 2006
They tell you to pull the fuel pump fuse so it not dumping fuel the whole time you are tuning it.
I have a predator and had a superchip tuner on my old truck and never pulled any fuses on either. Never had a problem
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
O
WTB Looking for an SCT X4 tuner for my 2005
  • optionizerSS
  • Jun 8, 2026
  • Want to Buy
Want to Buy Jun 8, 2026
optionizerSS
O
