I'm trying to tune my 351w, which has a new cam/heads (cam is a comp cams XE274H, which has an optimal rpm range from 1800-6000, advertised duration of 274 i/ 286 e, duration at .050 of 230 i/236 e, and max lift of .520i/.523e). Rest of the engine components are in the sig below.
I'm having trouble getting it running right. It has been difficult to start (sometimes starts right up, sometimes the starter turns the motor over 4 or 5 times slowly before it kicks), feels like its missing, and has proven difficult to time correctly. I also have no experience with high-performance engines... things like idle speed, timing, etc.
My specific questions:
1) What is the ideal idle speed for this engine/cam combo? My Holley Street Avenger has a default 'fast idle' speed (i think for when the engine is warming up) of 1500, is that okay? And I'm assuming the regular idle speed should be higher than stock type engines (which I usually set at 600-700)... what should that be?
2) We installed a new harmonic balancer with the engine. Its timing marks seem to be way off. Is this common? It currently indicates (with the engine running) that the engine is pullying between 45 and 55 degrees (eyeballing it of course, the marks don't actually go that high) of initial timing. The piece itself seems nice, its a 'Professional Products' press-fit balancer from PAW. I'm pretty sure you can't install the balancer at the wrong angle... am I right?
3) My engine is still hard to start (as described above, and in a thread I made a week ago or so), and feels like its missing while driving... it has a herky-jerky feeling while driving around. The sensation fades a little with rpm but is still noticeable.
Some people had said if it isn't timed right that might explain the hard starting, and probably could explain the missing sensation.
How should I go about timing the engine, since the marks appear useless? Just find peak vacuum? How much vacuum should it pull?
4 Somewhat related, is it possible that I installed the distributor a tooth or two off either way? Would the engine run like that?
5) Anything I'm missing?
Thanks a ton!
Thanks a ton!
). You shoulda just made the hour and a half drive up to Thousand Oaks while you were out here, I'ms ure you would have had it running like a top in 20 minutes
