Turbo/blower Guys....what Rings Do You Use?
As long as you use epoxy to do it
I use epoxy everywhere no doubt. I used it to glue that plate that widens the deck...( it never sees pressure, from water, oil, or combustion). It's only purpose is to hold on a plate, that widens the deck.
And I use it to seal threads,....permanently.
It's JB weld,..it's great for a lot of stuff, but I don't use it everywhere.
http://www.hotrod.com/articles/dyno-tested-thin-piston-rings-worth-horsepower/
Over the past weekend, I watched some of those Engine Master vids. They a 5/64 vs. 1.5 ring comparisons. The same exact piston in a SBC with different ring packages. The torque required to rotate the shortblock was vastly different. 37ft vs 14ft for the 1.5 mm rings. That's a huge difference. But the dyno don't lie. I think it was worth 7hp and 4 ft lbs. On a 3.7 bore the difference would be much less. On a 4.5 bore, much more.
I think it is not enough of a difference to justify spending money to get custom pistons. If your pistons aren't hurt, then new rings, gapped appropriately. When I slap that junkyard 351 in I think I am running the cast pistons, but may spring for the Total Seal gapless rings. If I put that BD11 on it, it won't make more than 6psi, so that should work for me.
Reactions: HotFox
But the dyno don't lie. I think it was worth 7hp and 4 ft lbs. On a 3.7 bore the difference would be much less. On a 4.5 bore, much more..
4.5" bore....you are talking big big block territory. 500+ cid stuff. Not exactly relevant.
BTW, the rings in my blower car are 1/16, 1/16, 3/16 for what it is worth. Gap-less second ring.
I have custom pistons.
I know...I meant I wouldn't go order another set just to change the ring package. It's just not worth it.
My failed point was that moving to low tension or smaller ring package helps the larger the bore is. At 3.7 I be the difference is within the measuring tolerance of a dyno.
