Turbo Build
  • Thread starter Thread starter Nikia
  • Start date Start date Aug 31, 2014
  • 3
  • 7
1 of 7 Next Last
N
Nikia
31
Aug 31, 2014
  • Aug 31, 2014
Hello. I am looking for advice on my turbo build. As of now, the only aftermarket parts I have are MSD ign, and 70mm TB. I am wondering what parts im missing from my build.
*Eagle Specialty Products B16006LA030 forged pistons, rods and cast steel crank.
*Sealed Power MK6256A-311 - Federal Mogul Premium Engine Rebuild Kits
*Cxracing t76 turbo kit
*Wide band
*Fuel pressure
*60 lb injectors
*F303 cam
*Performer RPM II
*Gt-40x
*Studs
*1.6 rockers
*Fuel pump bbk255
*Bbk Rails
Radiator/fans
madspeed
Colonel Mustard
1,332
204
a van down by the river
Aug 31, 2014
  • Aug 31, 2014
Thread moved....
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Aug 31, 2014
  • Aug 31, 2014
Missing a bunch of odds and ends, but you are off to a good start.
Kurt
Reactions: Nikia
CarMichael Angelo
8,909
234
Birmingham, al
Aug 31, 2014
  • Aug 31, 2014
Reactions: Gearbanger 101, FastDriver, 5point0stang88 and 6 others
Admin Dude
Jan 4, 1985
43,577
21,741
234
Box behind Walmart
Sep 1, 2014
  • Sep 1, 2014
madmike1157 said:
This is true. I've re-checked and did not see this item on the list.
Reactions: stangboy
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Sep 1, 2014
  • Sep 1, 2014
Don't forget jackstands. Turbo cars spend approximately 78% of their life on them.
Reactions: tannerc91gt, stangboy and MikeH686
N
Nikia
31
Sep 1, 2014
  • Sep 1, 2014
I understand it will be expensive, what I have listed here, I have budgeted at 6975 I'm wondering if there is any other major expenses. Stock ecu on new intake?
bentley429isBAC
922
188
84
CT
Sep 1, 2014
  • Sep 1, 2014
Don't do any fancy bottom end parts. Stock rebuilt 302 will be fine. There are better options then gt40x, twisted wedge or afr185 would be better. Stock ecu with a SCT chip will be a good idea. Need more fuel pump and your probably going to max out the lines. Trans is going to fall out also.
stangboy
3,932
469
194
New Orleans, LA
Sep 1, 2014
  • Sep 1, 2014
How much power are you trying to make? That T76 will make some power...probably more than what that stock block and cast crank can handle.
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Sep 1, 2014
#10
  • Sep 1, 2014
  • #10
I'd do the h/c/i first. Get it running and driving, then worry about the turbo later.
This way if you run out of money (and it happens), you at least have a good car to drive around and enjoy.
7 grand may sound like alot.
During a complete turbo build, it's not.
Reactions: stangboy
stangboy
3,932
469
194
New Orleans, LA
Sep 1, 2014
#11
  • Sep 1, 2014
  • #11
I'm about 13k into my 363, tranny and rearend build. Putting a turbo on it would probably be an additional 8-10k for a nice turbo setup(88mm is what I would want if/when I go turbo )
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Sep 2, 2014
#12
  • Sep 2, 2014
  • #12
Good point.
Let's not forget the transmission. A TKO setup is a minimum of $2500 these days and with 500rwhp on tap the t5 probably won't even make it a week.
CarMichael Angelo
8,909
234
Birmingham, al
Sep 2, 2014
#13
  • Sep 2, 2014
  • #13
Now having first hand experience at a "turbo build", It all comes down to what you can, and can't do. The turbo was 700.00 and was by far the single biggest expense. Had I stayed true to my original plan and went w/ a Ebay GT45, that would've been cut in half. The waste gates, and BOV (again Chinese pieces) added another 220.00 The 60 lb Injectors were 300.00, although I bought a A2W, an A2A IC can be had for 100.00. The header and material to build it, and the coldside was another 200.00. The silicone couplers, and the T-bolt clamps another 100.00. And I'll concede to a slush fund of 150.00 for stuff I've over looked.
That's 1770.00 if you can do it, or you can just buy the CX Racing kit for the exact same price, minus injectors.
** But after looking at pics of the kit,...it looks to me like you better possess some of those skills.
Reactions: stangboy
madspeed
Colonel Mustard
1,332
204
Sep 2, 2014
#14
  • Sep 2, 2014
  • #14
how many miles on the current motor?
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Sep 2, 2014
#15
  • Sep 2, 2014
  • #15
a good 76 mm turbo can make a lot of power.
good luck, it gets expensive if you use good named parts, which I would suggest.
Reactions: stangboy
stangboy
3,932
469
194
New Orleans, LA
Sep 2, 2014
#16
  • Sep 2, 2014
  • #16
Not to hijack the thread or anything, but since we're on the subject.... How much would a quality name brand 88mm ball bearing turbo cost? I don't know how to weld and I have never done any fabricating, so how much (ballpark figure) would it cost to get the tubing fabbed? I figure those would be the most expensive parts to piece together a turbo setup. @GroverDill @madspeed @madmike1157
madspeed
Colonel Mustard
1,332
204
Sep 2, 2014
#17
  • Sep 2, 2014
  • #17
Sounds like you're getting in way over your head. Have you ever driven a boosted v8?
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Sep 2, 2014
#18
  • Sep 2, 2014
  • #18
My non BB Precision 76GTS on my 363 made over 950 at the wheels thru a viper spect t56
Using a 3" downpipe (OMG!) My car is not a racecar so I have never considered larger.
I think my turbo was about 1500 bucks. The hot side was made by a local friends shop ( its flipped JBA 1 3/4" shorties )
I put the cold side together in my garage, easy as could be.
Reactions: stangboy
stangboy
3,932
469
194
New Orleans, LA
Sep 2, 2014
#19
  • Sep 2, 2014
  • #19
Are you pushing the turbo close to it's limit with that setup? I don't even need to make 950 to the wheels....right now, but I don't want to get a turbo that would be at or close to it's limit giving me 800 at the wheels. I always try to think ahead as though I might want to upgrade/go bigger. So I wouldn't want to get something that's just making it on my 363 and it run out of breath if I put it on a 427.
I'm not sure you're directing this towards me or not but I have driven my buddy's twin turbo'd stroked 3-valve 05 GT.
This is how it went most of the time ---> A lot of tire frying. Was a little scary at times...I don't really like ice skating.
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Sep 2, 2014
#20
  • Sep 2, 2014
  • #20
you are concerned about a $1500 turbo
but will swap form a 8k 363 to a 9k+427
I dont see the logic
Reactions: f8tlfiveo
  • 3
  • 7
1 of 7 Next Last
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
Progress Thread Evolution of the 'Hudson Heap' plans (87 GT)
  • MadSquirrelTech
  • Jan 5, 2024
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 26, 2024
Fox Build ideas for the 'Hudson Heap' (87 GT)
  • MadSquirrelTech
  • Sep 19, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 27, 2023
MadSquirrelTech
302 Engine build questions
  • Vulpes5.0
  • Apr 19, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2022
LEEDAY Boss
