Well, the money is there, and the car is coming to my shop where I work hopefully this weekend. Then come the parts. Then come the headaches all over again !!
Hopefully I've learned enough the first time to save myself a few of them.
See heres the plan so far. Headers, crossover with flex tube.Turbo and wastegate. All plumbed together with thick 16g aluminized steel (mandrel of course). The DP with be 3in mandrel, and run to just under the foot of the floorpan. Would like to plumb the wastegate into the Dp, but not sure yet. The kit will come with a BOV which I will weld the flange to the cold side. I'd like to make a complete kit. But there are too many variables with carbs, intakes and spacers. So I want to weld the flange to a 2ft pipe. Send it with a carb hat, and silicone hose. Then from there all you have to do it clock the turbo(easy), and fit the piping to the hat. Oh yeah, it will come with a GOOD carb hat gasket that has held so far no problem to 32psi.
Further break down.
Master power T61-2(probably) or a MP T-70 depending on how crazy you want to get.
.81 housing will be standard, .96 will be an option, as well as a .68 for pure street car (also a little cheaper).
BOV and wastegate will be Tial 50mm and 38 mm respectively
V-bands and flex pipe will be stainless steel.
This is where most of the cost comes. Plus the 200 carb hat, and all the pricey mandrel bends.
Jet hot coating is always an option, but to keep costs down, not the standard. Until I can do it myself cheap anyways.
Depending on final costs of the parts I get, is 2400-2600 sounding pretty good ?
Hopefully I've learned enough the first time to save myself a few of them.See heres the plan so far. Headers, crossover with flex tube.Turbo and wastegate. All plumbed together with thick 16g aluminized steel (mandrel of course). The DP with be 3in mandrel, and run to just under the foot of the floorpan. Would like to plumb the wastegate into the Dp, but not sure yet. The kit will come with a BOV which I will weld the flange to the cold side. I'd like to make a complete kit. But there are too many variables with carbs, intakes and spacers. So I want to weld the flange to a 2ft pipe. Send it with a carb hat, and silicone hose. Then from there all you have to do it clock the turbo(easy), and fit the piping to the hat. Oh yeah, it will come with a GOOD carb hat gasket that has held so far no problem to 32psi.
Further break down.
