Turbo install: engine cuts out while idling
squeak_cg
153
Lima, OH
Hey guys,
I put a HP Stage 3 turbo kit on my car w/the 76mm turbo. I have everything installed and the engine running. The car idles fine, however, if I let the engine idle for about 15 minutes it will sputter and die. When I try to restart, the engine will crank but not fire. I do have spark and the fuel pump primes in this condition.
I am just trying to get it running reliably before I tune it. Do you have any ideas what to investigate? No problems similar to this pre-turbo install. If I wait a few hours and come back to it, it will fire right up.
Other info: I'm running the stock computer w/a 76mm CL MAF, stock distributor and ignition, no FMU.
Thanks for any help guys, if you have any questions for me, please ask.
Where are the O2 sensors located? Both in the DP or in each header? I had a similar problem back in the summer which ended up being the fact both O2 sensors were in the down pipe. They were fighting each other i suppose you could say, unplugged them good as new. Tuned the car without them.
One sensor is on the driver side header and the other is on the passenger side header just before the headers come together. I don't have any proof that both O2 sensors work though. One came with the used kit that I got so I have never used it before on my car.
I do have three empty O2 bungs that I have plugged for now. One of the extras is located on the downpipe about 6 inches after the turbo and the other two are further down the downpipe, about 4 feet after the turbo.
I will try to unplug them and see how she runs for now. How can check if your O2 sensors are sending a good signal? How did you end up tuning yours? I'm planning on getting a pms once I get everything running correctly.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Toss that mass air out the window
ya, seriously.
As for i disagree with running that meter on a NA car, i'd multiply that opinion 10 fold on a turbo car.
Probably not your problem now, but i wouldn't even attempt a tune with it, just a waste of your time.
As far as your problem, i'd consider the two things that get heat soaked and cause a car to stall and not restart until it's cool.
The coil and the TFI.
If you have spares try them out.
okay, I've pulled my codes,
With the key on I get 81,82,84,and 85 (I did pull off the charcoal cannister and the other emissions equipment)
With the engine running the check engine light will just blink 4 times.
Before any codes are displayed it will not give a code 11, it will flicker the check engine light for a few seconds and then display the codes.
Today, the car will idle, then the idle will surge and the car will die as before, but I will be able to restart it. However, after doing miscellaneous things like jumpering the diagnostic port or pulling the spout it will not start. If you wait, after an extended period of time you will be able to restart it.
When it won't start I do have spark and the fuel pump will prime.
Any ideas guys? Thank you for the help
See the "Surging Idle Checklist for help with all your idle/stall problems. The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
