Turbo kit or SC?
  • Thread starter Thread starter 93steeda
  • Start date Start date Mar 12, 2004
9
93steeda
50
North Carolina
Mar 12, 2004
  • Mar 12, 2004
Which is easier on the motor and easier to control as a daily driver. Im getting ready to order one or the other, just cant make up my mind. Not worried about price differences just want something that is reliable.
donkey_punch
565
northern****ingjersey
Mar 12, 2004
  • Mar 12, 2004
none of them are easy on the motor.
what you want is a low psi on either a sc or turbo. which in turn is not worth the money to go low on the psi.
and trust me price does make a difference. cause to get the most and best performance out of either one. you have to do other mods. like beef up your fuel system, MAF etc.. everything adds up.
but in the end the choice is up to you.
maybe someone else can shine more light on this.
TwinTurbo93
153
Orlando
Mar 12, 2004
  • Mar 12, 2004
Turbo is going to be easier on the motor and have better manners on the street. A turbo car will drive and idle like a stocker until you get into the go pedal, and it uses exhaust gases to spin it, unlike a supercharger which puts lots of pressure on the snout of the crank. Get a turbo kit and you wont be dissapointed, turbos rule the world.
88stangmangt
2,332
Stafford,VA
Mar 12, 2004
  • Mar 12, 2004
i got a vortech for now later on when i build my r-302 block i am gonna be looking for 15-20lbs of boost. i might be looking into a turbo then. as for now 10lbs with the vortech will have to do.
DirtyD916
804
Norcal 916
Mar 12, 2004
  • Mar 12, 2004
if money is no problem then turbo is the definte answer. It provides gobbles of boost, great up top power, and doesnt put as much pressur eonm the crank like tt93 said. However wiht any power adder situation, yopur going to have to factor in the fuel system, maf, upgraded suspenison (optional), and better h/c/i to go along with that power adder.
DirtyD916
804
Norcal 916
Mar 12, 2004
  • Mar 12, 2004
oh ya iand i forgot to mention that inlike a supercharger where you have to have different belts and pulleys to change boost levels, you just simply turn a dial with a turbocharger to make street use very possible.
bmo37
2,368
New Jersey
Mar 12, 2004
  • Mar 12, 2004
with turbos since the power is alot more you better have a strong lowend, the stock 302 block even with a main support girdle isn't going to last too long, those caps will walk sooner or later. If money was no object i would go for a dart block with a main support running a tt setup.
I
Iwant5.0
89
NC
Mar 12, 2004
  • Mar 12, 2004
goto www.turbomustang.com and go read there forums. There are lots of guys on there running a TT Setup on the stock longblock and still be reliable.
TwinTurbo93
153
Orlando
Mar 13, 2004
  • Mar 13, 2004
Yep thats very true, Barry D. has been 10.30's with the stock block/internals and it lasted quite a while! As long as you aren't going over 500 rwhp you should be ok, as long as you have a good tune.
IMissMy93Fox
143
#10
  • Mar 13, 2004
  • #10
Don't count out ProCharger.. like was stated before it's easier to adjust the boost on a turbo but ProChargers are putting out very similar power numbers.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
N
New Edge 3.8L Forged Internals
  • NtheGAME
  • Jun 1, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 3, 2025
