  • SN95 4.6L Mustang Tech
Turbo related issues
  • Thread starter Thread starter gogoCOBRA
  • Start date Start date Jun 7, 2005
G
gogoCOBRA
18
Virginia
Jun 7, 2005
  • Jun 7, 2005
What if I get twin with larger turbos, will that help with top end?.. I guess V-motor should go with Twin setup? My buddy has a large single in his 98 supra and that thing will dip you on the highway..Do you think my stock motor, clutch, tranny, and irs can handle the power at the track or everyday driving?..I'm not planning on gunnin this thing every chance I get.. but its good to have--thanks for your help
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Jun 7, 2005
  • Jun 7, 2005
two small twins will give you more than enough power. you don't need big turbos to make alot of power, unless you want something crazy like 1500rwhp.
your stock pistons and rods won't handle much more than 400rwhp. the tranny maybe 500rwhp. the clutch will need replaced for the best performance. swap the IRS for a solid axle.
G
gogoCOBRA
18
Virginia
Jun 7, 2005
  • Jun 7, 2005
if I go with PTK T-76, what internal mods should I do on the 03?.. oh, and tranny, clutch, and rear-end as well?
hotmustang331
2,967
Bastrop,TX
Jun 7, 2005
  • Jun 7, 2005
What dmstang LOL...dude your 03 cobra internals will handle 800+RWHP...tranny will hold a little over 600-700RWHP with a different input shaft and a spec stg 3 clutch...rearend needs to be upgraded to a 8.8 with auborn and full 31 spline equipment...You may want to go with the next spline up like 36.
G
gogoCOBRA
18
Virginia
Jun 7, 2005
  • Jun 7, 2005
thanks hotmustang331, you think I should go with a t-76 or TT setup?
hotmustang331
2,967
Bastrop,TX
Jun 7, 2005
  • Jun 7, 2005
like said in the other thread, the TTs would be much more predictable and wouldnt hit so hard and suddely as the single...go here www.turbochargedpower.com and look at their cobra TT kit...thats the one you want, and they are mounted under the bumper but the sigles are right in front of the engine and produce alot of heat, combined with the heat of the engine wouldnt be a good idea. HPs TTs are a very good system and thats what i will be getting, but 600-650RWHP is my goal. Just be careful when getting into the boost. BWT about the TTs vs the singles, the TTs hit at a low RPM (meaning quicker power and less of an intial power burst as the RPMs are lower= more control) the single will take longer to spool up and resultingly will hit harder and more suddenly as it brings the power up to where it should be, but since your further in the RPM range at that point you have more power hitting...so basically the TT kit will beat teh single in a drag race at the track. Hope that helps.
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
J
Forced Induction Turbo SBF Fuel system RECOMMENDATION
  • Jschallitz
  • Jul 31, 2024
2K
Fox 5.0 Mustang Tech Aug 2, 2024
Monkeybutt2000
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
