  • 1994 - 1995 Specific Tech
Turbo setup question
  • Thread starter Thread starter 94_5.0
  • Start date Start date Apr 12, 2004
9
94_5.0
337
Jacksonville, NC
Apr 12, 2004
  • Apr 12, 2004
I was planning on adding a single turbo setup to my stang. I was wondering how much boost can I run before I blow the engine up and what type of setup would be good. I am planning on adding T/F Twistede Wedge heads and will be tunning it with a Tweecer R/T. is there anything that I need to do befor I do the turbo setup. Thanks in advance for all of the help.
Y
yellow1995Cobra
2,959
Massachusetts
Apr 12, 2004
  • Apr 12, 2004
You can run as much boost as you want, just depends on the tune.. If your seeing 15#'s with h/c/i, ur likely gonna split the block. I would say 8-10 is a good ammount, and you will make tons of power with heads and cam. Just remember that boost is just a measure of backpressure.
If your tunning with a tweecer, be sure to get a Wideband, so you know what ur air/fuel ratio actually is.
I poped a HG after running my turbostang for 4 nights. My own fault though, was running it without a tune and beating on it. I am getting it dyno tuned on friday though.
9
94_5.0
337
Jacksonville, NC
Apr 12, 2004
  • Apr 12, 2004
I thought that the R/T had a wideband option on it...donen't it that is why I bouth the R/T. Am I wrong about that option? Also will I need to up grade my T/B and Maf with a turbo?
9
94_5.0
337
Jacksonville, NC
Apr 12, 2004
  • Apr 12, 2004
One more question where did you get your turbo setup and how much was it all said and done (if you do not mind my asking)?
Y
yellow1995Cobra
2,959
Massachusetts
Apr 12, 2004
  • Apr 12, 2004
No, the tweecer does not tell acurate air/fuel ratio. You need a wideband. I had a tweecer RT but decided to get rid of it, because tuning with boost is not somehting i want to mess around with.
If you buying used, you can save some cash.
I got my whole PTK kit used for 2400, the cold side was recoated before i got it. Everything in great shape. I picked up the SC61 turbo new from precision for 750(polished compressor cover).
So 2400+750 = 3150 total for the turbo part.
Yes you will need a new MAF, and bigger injectors. I would run 42#'ers, dont forget fuel pumops too!
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
