whell, after i just blew my headgasket last night, i was thinking of re-mounting my turbos up front. For a number of reasons, most being That my airfilters are sucking in water in the rain, and ground clearance, the faster spool wont be bad eaither. Anyway, i was told that my current setup would be legal or MASS inspection as long as I installed my stock h-pipe.
My question is this: If i front mounted my turbos, and made the downpipes connect to my stock 4-cat h-pipe, then through the normal exhaust system, would this be legal...assuming it actually passes emmissions? After i would switch it to my x-pipe.
Thanks guys, just looking for a bit of info before i start chopping.
Pretty soon you will be a Pro
You can't modify you're exhaust EXCEPT for cat backs. Those are California legal, at least my flowmaster catback is.
