ok, so i bought some led's to replace my turn signal up front....they look good i think. nice and bright. but they are not working properly....
i have sequential turn signals and when i replaced my regular bulbs with these led's they started going way too fast.
When i put the hazard lights on with the led's they work just fine and go at the slow rate so that way they can sequence out.
But when the leds are in and i use my turn signal like normal, it speeds up and the Sequential turn signals dont work the right way. instead of all 3 bulbs on that side lighting up, only one will light up.
So the led's only work properly when the hazard lights are on.
i checked to make sure that they were in the right way, when i fliped them over and pluged them in the other way. they would not even light up.
so i swaped the leds out and put the regular stock bulb in and now my Sequential tail lights work fine.
Does anyone know why this is happening?
I had a similar problem to this a long time ago when my flasher was not plugged in all the way. but obviously it has something to do with these led's.
im wondering if its these specific bulbs, or is it just becuse they are led's???
