turn signal trouble
when you say you replaced the switch, do you mean the ignition switch or flasher switch?
I had a similar problem (signals wouldn't work) and it was the ignition switch. They're like $15 at autozone and it takes like 10 minutes to do it.
Good luck:nice:
Check the wires going from the turn signal relay to the multifunction switch. There's a light blue one that runs directly from one to the other. I had no turn signals for a month or more before I realized the wire had pulled itself out.
