turn signals don't flash
  • Thread starter Thread starter jrwhitley
  • Start date Start date Feb 15, 2004
J
jrwhitley
  • Feb 15, 2004
Recently I inspected, cleaned and lubed my speedo cable, disassembling the dash, carefully removing the instrument cluster as is necessary to perform this operation.
I reinstalled everything carefully and it all works great, including the lights, except my turn signal flashers don't flash.
I checked the fuse and it's fine. The underdash turn signal flasher in my special service '93 5.0 coupe appears to be different than the flasher shown in the '91 factory service manual I'm using.
Do any of you out there have some solid suggestions based on first hand experience?
I would appreciate any help.
Thank you,
jrwhitley@earthlink.net
Mavrick
2,264
Collingwood, ON
Feb 15, 2004
  • Feb 15, 2004
Is it the interior dash lights that don't flash, or only the exterior signals that don't flash? Or both?
TheFleshRocket
208
Southern Ill Annoy
Feb 15, 2004
  • Feb 15, 2004
No flash usually indicates a bad blinker relay or a dead blinker bulb.
You sure it's not just a coincidence?
HO93LX302
715
Naugatuck,CT
Feb 15, 2004
  • Feb 15, 2004
The mulit function switch could be bad.. Do your high beams work? high beams and turn signals work on same circuit in the multi function switch and the wipers work on the other circuit
C
crazy_canuck999
137
Victoria, BC, Canada
Feb 15, 2004
  • Feb 15, 2004
well, one easy thing to check if it's the flasher, change your turn signal flasher with your hazards flasher (assuming your hazards work), and test out the blinkers.
fordman54935
301
Wisconsin
Feb 16, 2004
  • Feb 16, 2004
I had this happen to me once. Checked the fuse, it was fine. Swapped the flasher unit from my 88 over to my 93, still not working. It turned out to be that my hazard light switch was accidentaly pushed about halfway between the on and off position. This made the blinkers not work....Worth checking out I couldn't believe that something like that made the turn signals not work....but hey, we learn something every day.
J
jrwhitley
  • Feb 16, 2004
thank you!
i will check my hazard switch this weekend.
J
jrwhitley
  • Feb 16, 2004
turn signals don't flash-
both.
and thanks.
FiveOCapri79
164
Lawton, Oklahoma
Feb 16, 2004
  • Feb 16, 2004
Funny, but I'm having this same problem as well. Hazards work, high beams work, but no flashing whatsoever on the dash or exterior.
J
jrwhitley
#10
  • Feb 16, 2004
  • #10
turn signal flasher
hi-beams, lo-beams, parking lights, hazard flashers, everything works perfectly but the turn signal flashers.
thanks.
J
jrwhitley
#11
  • Feb 16, 2004
  • #11
same problem-
i'll let you know what the solution is once i figure it out.
you let me know if you figure it out first.
thank you, and best of luck.
J
jrwhitley
#12
  • Feb 16, 2004
  • #12
coincidence?
could be a coincidence but-
everything (but the speedo cable) was working perfectly before i disassembled.
thanks.
J
jrwhitley
#13
  • Mar 3, 2004
  • #13
i solved it.
the turn signal flasher was the problem. on my '93, it's above the glove box.
dumb simple to access.
on earlier fox bodies it's above the fuse panel.
i borrowed the hazard flasher from the fuse panel and tried it on my turn
signal receptacle and it worked. they simply unplug (two prong plugs).
note: if this is your problem, replace the flasher with a turn signal flasher, not a hazard flasher.
best.
M
mi2fast
36
Hellcentro Ca
May 9, 2004
#14
  • May 9, 2004
  • #14
i am having the same problem, my 89 mustang, the turn signals aren't working. I checked the bulbs, the fuse box under the steering wheel all good, replaced both flashers, replaced the actual assembly on the console. Hazards are working perfectly. No clue, any help?
M
mi2fast
36
Hellcentro Ca
May 17, 2004
#15
  • May 17, 2004
  • #15
Figured mine out the wire cluster under the steering column has a pretty big connection under there and the clip that holds the connection was broke, so the connection wasn't making connection. Here are the pics, a simple zip tie holds the connection together now.
R
ratrapp
510
buena vista,va
May 18, 2004
#16
  • May 18, 2004
  • #16
you probably did the same thing i did when i replaced my speedo cable.one of the wires had pulled out of the hazard switch on the dash and everything worked except the signal lights.you'll find this is a very common problem amoung stangs if you search the threads.
F
foxx5.0
nashville tennesee
Oct 2, 2018
#17
  • Oct 2, 2018
  • #17
Okay my 1991 5.0 lx turn signals dont work, sometimes..... i have been dealing with this for a couple months,,, but i didnt even realize its not just my turn signals, its my ac/ heat, defroster, vents, when one isnt working; they all arent working. ill be driving without them then all of a sudden they will all magically start working together,,,, ive tried fuses, ive replaced the flasher relay too... it sucks because i dont want to be pulled over AGAIN, CAN ANYONE HELP ME
General karthief
Mod Dude
Aug 25, 2016
28,143
10,762
213
polk county florida
Oct 2, 2018
#18
  • Oct 2, 2018
  • #18
You are posting to a thread that is 14 yrs old. Start a new thread and tell us whats happening, or not happening in this case, and what steps you've taken to rectify.
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Oct 3, 2018
#19
  • Oct 3, 2018
  • #19
It's a loose wire somewhere.
Since it's all going out at the same time, you know it's early in the circuit that the problem is happening.
Get the ford wiring diagram for your car.
R
RRJ
Utah
Oct 9, 2018
#20
  • Oct 9, 2018
  • #20
This is likely an ignition switch not coming back all the way to the “run” position. If so, You’ll find your reverse lights don’t work as well. When you have issues, turn your key back slightly toward the off position. If things come back on, it’s the switch... a $20 fix.
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
G
68 Mustang - Cluster and turning signal lights intermittent after upgrading to LED
  • grantosmond
  • Jun 14, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 14, 2025
grantosmond
G
O
Getting things to work and display correctly on my cluster. I would appreciate anyone's two cent's worth.
  • OfflineHomestead
  • May 7, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2024
OfflineHomestead
O
No brake lights and turn signals don’t flash
  • Andresquintana.mma
  • Nov 14, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2023
AeroCoupe
M
Electrical Headlight switch not working properly
  • MaxFerguson
  • May 26, 2024
Fox 5.0 Mustang Tech May 26, 2024
rednotch
