TURNING PISTONS 180 GETS 30 HP?????
XBLCanterX
34
Lexington
I was talking to a buddy of mine who builds 302's for some local mustang guys and he told me that if you turn the piston heads 180 degrees in the cylinders it'll get you around 30 extra HP. I said BS...but he says hes got Dyno numbers to prove it. I will have to wait and see...but has anyone else heard of this? He said it bumps up the CR because you move the larger intake reliefs to the flat spot of the chamber and use the smaller exhaust reliefs instead. Makes sense but wouldnt that cause clearance issues though??? Just wondering if its true.
I also have heard of this, but it is because it give's the piston more leverage on the rod. Move's the piston pin at TDC to the correct side of the leverage point and a increase of power is the result. I've heard of gains, but not 30hp. Also, tends to have a lot of piston noise untill engine is warm.
:rolleyes: :( :D
Nate
:rolleyes: :( :D
Nate
that makes more sence than the retarded compression idea lol
NO!!! Piston pins are offset to reduce wear on the major thrust side. By rotating it 180*, you will cause MORE friction and INCREASE the wear. Do not do it. Piston mfr.s know what they're talking about. If there was any sort of gain involved with doing such a swap they would tell you to install the pistons in that fashion in the first place.
Yes,.. there is more wear and tear,... but from the people I've talked to this is not a big thing for a strip/stock elim/NMRA class legal type car that it would be used for. daily drivers need to build it the right way. :D
I've heard of it before as well. Even saw some artcles on it. Don't beleve everything you read or everything that people tell you. If you turn a 347 piston around you run into big problems. Even if one piston is turned around.
