  • 1994 - 1995 Specific Tech
twEECer and Emissions?
  • Thread starter Thread starter Therian
  • Start date Start date Jun 21, 2006
Therian
The Highlander
Waterloo, Ontario
Jun 21, 2006
  • Jun 21, 2006
Hey guys,
I just got off the phone with Jay Allen and all seems well with the combo I would like to build except for one big stumbling block.
In Ontario, the e-testing is pretty brutal, visual inspection, drive test and curb side idle. The cam I would need to run with my setup would in no way pass emissions (basically it would make power to 7500 rpm).
Is there a way to down tune with a tweecer that would allow the car to pass emissions relatively easily? something tells me this won't be happening
fack
Swarzkopf
973
Pittsburgh
Jun 21, 2006
  • Jun 21, 2006
Well...the less fuel getting to the engine, the better emissions are.
Don't know how safe it is for your engine, but you could cut fuel pressure way down...
Not advising this, just brining it up...
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 21, 2006
  • Jun 21, 2006
I have posted several times before about my clean burn results with my Ed cam and Tweecer tuning.
We got strict emissions testing here is Texas with the mini dyno rollers and they check at idle, steady cruise, and elevated rpm levels.
Use the words Texas or annual state emissions with my name in a search and you can see all the details.
btw, my cam lsa is kinda on the low side and the combo would not idle, run you out of the garage due to rich fumes, stall & buck with the t4m0 GT file.
The Tweecer and a switch to the Cobra j4j1 file and a tweec or two from yours truly made good power/drivability, and no probs with the emissions inspection that comes around yearly.
Based on my findings ...... The Tweecer does give one pretty good pcm access to the stuff needed to change which can make things much better than they would first think if they had never had experience with self tuning before.
Good Luck
Grady
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 21, 2006
  • Jun 21, 2006
#1 The factory 4 cats + EGR rule. My car literally put out dead zeros in HC and CO (with factory h/c/i though).
#2 fully functional O2 sensors are critical. If you a/f ratio deviates anywhere from 14.64 the emissions output sky rockets (richer or leaner).
#3 You can always rig your smog pump to run all the time. This will make any emissions output insignificant as it will read mostly clean air. Last resort if you still can't pass.
Scott
Therian
The Highlander
Waterloo, Ontario
Jun 22, 2006
  • Jun 22, 2006
Does anyone have a cam with specs around 232 dur. @ 050 lift and around 560 lift with 1.6 RRs?
Could a cam in this area pass emissions somehow?
stupid driveclean
OrangeMustangGt
1,976
Cape Cod, MA
Jun 22, 2006
  • Jun 22, 2006
im with you on this. I have to pass emmissions this month. My only issues i believe are my crane 2031 cam (which they say is emmissions legal) and my 42lb injectors......we will see!
blksn955.o
3,263
st.louis mo 314
Jun 22, 2006
  • Jun 22, 2006
We have a roller dyno deal here as well. Well the smog company is getting the boot out of our state in 07 though
I have heard of people un-doing the front two or rear two inj. from the inj. and passing.
A good cat, o2's, smog pump and EGR that is working should pass though.
P.S. I only have to deal with passing until sep./oct of 07...then the new law kicks in and I am exempt and dont even have to get the plug in test for CEL's.
mootang
907
texas
Jun 22, 2006
  • Jun 22, 2006
GreenMustangGT, do you still have all your smog equipment with the twins?
WhiteDevil
2,717
San Diego
Jun 22, 2006
  • Jun 22, 2006
We all know that cali has some pretty tough smog and with set up i passed EASILY! I was soo far under on all aspect. One key is the stock H that thing cleans like there is no tommorow. I have a functioning EGR and smog pump as well. I was no where close to failing. That said i got failed for my FPR so i threw the stocker on and passed.
Therian
The Highlander
Waterloo, Ontario
Jun 22, 2006
#10
  • Jun 22, 2006
  • #10
It seems as though most of you guys have pretty mild cams...I would expect most of those to pass as long as the rest of the emissions crap is in working order.
Anybody with aggressive cams passing the etests?
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
A
Help with engine issues/emissions
  • Artyom
  • Apr 11, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 12, 2024
Mindseye007
D
Electrical Manual 2003 GT 4.6L coupe that will not start. Thoughts? Resources?
  • DapperFish
  • Jan 17, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2024
PSKSAM2
P
Emission Testing Issues
  • superstang01
  • Mar 12, 2018
1996 - 2004 SN95 Mustang -General/Talk- Mar 13, 2018
rancorkeeper
9
Exhaust 92 5.0 gt mustang- emissions/brakes/vaccume leaks/exhaust/CEL
  • 92.302.gt.5.0
  • Jun 15, 2018
3K
Fox 5.0 Mustang Tech Jun 16, 2018
jrichker
