Tweecer And Wideband Question
Most all widebands will work if they have an analog out wire. I havent heard any real complaints yet about Innovatives, PLX, Zeitronix, FJO's or Dynojets.
To get it to read in the Tweecer dashboard though you need to have removed your EGR system so you can wire the analog out into the old EGR signal and tell the Tweecer you are using "DIYWB" on the EGR signal line.
Even if you do it that way, its might still be a good idea to get one with a display. That way - if the calibration is a tad off or you dont have a good signal connection you will know because the Tweecer and the display will differ.
-Jason
If you shop carefully you can pickup a Dynojet WBC for $350. Includes analog gauge & brainbox, O2 sensor, and all wiring. Can be used to datalog and download later, or datalog real time. And can be configured to display a warning light under specific conditions (very handy for a boosted application).
10-4 . yeah i just read the tweecer website. now i understand. i am looking a kenne bell and some other induction things. sounds like this would be an awesome thing to have. i would hope it would'nt overwhelm me though, i might screw up more than i fixed if i had that. does it replace an fmu for blown apps. ?
(not trying to rob your thread) thanks -
If you do not need the display... and will view the A/F with a laptop.. then you can use the new Inovative LC1... It retails for $199.00, or you can go to LS1tech.com, and get it for $169.00 if you buy it through Dynotune.. Look in the group purchase section...
If you wanna get into self tuning I would start with your na combo you got now :D
A forced induction combo it not as forgiving about mistakes :bang:
or
shall we say, :rlaugh: misunderstandings :rlaugh:
when your a noobie self tuner
Later
Grady
