Tweecer Noob, Help
Swarzkopf
973
Pittsburgh
Just bought a Tweecer. I'm trying to learn the CalEdit software before I actually try Tweecing anything.
Anyway, my car is a 95 GT. This uses the UP40 computer.
I assume that I need to use the correct "Strategy" defined at the bottom-center of the CalEdit screen, but I don't see a listing for UP40. Which "Strategy" should I select?
Also, I'm really only trying to adjust a few "Scalars" (to change my shift points, eliminate a few codes, and change my rev limiter)...this sounded easy enough after reading BlueOvalStangGT's sticky at the top, but once I get into CalEdit none of the scalars have the names that he was using, nor does the value stored even slightly resemble the values listed in his post. I assume this will change when I use the correct "Strategy"?
I couldn't seem to find these answers with searching. I appreciate your input.
