I have a 95 gt that I am installing a 351w into. I have an 80mm pro-m maf that is calibrated for 30lb injectors. I am going to running 36lb injectors. What do I do in the tweecer to make this work?
Justin
Justin
I just looked at a stock config on my PC....It has the LOW slope 20% higher.WhiteDevil said:Yeah change the scalars for the injector slopes to 36 and one 20% higher but i dont remember which one either. Then go into the functions and go to maf transfer and the click load MAF then load prom30 thats a good starting point.
Great thing about it is if you mess up, you just start over...no harm no fouliluv95stangs said:Ok, thanks guys. I have the flow sheet for my meter that I entered into caledit and converted it. I already checked it for the 'random zero' and it has none, so I will set my slopes as ya'll said and see how it goes. Thanks for the help.
Zero Signal said:3. Tune the timing and fuel tables <------- This step is the meat of the tuning
Pretty str8 forward
I still havent done this, but IM gonna be putting in the Snow Meth Inj kit Soon, so I may have to start learning.Its not "tricked" per se it just takes more air to create the same voltage as with the stock piece. So with the stock one 3.5v equals say 600kg/hr on the the 30lb calibration 3.5v is now 800kg/hr to make up for the difference in the injectors. If you have a pro-m maf the best bet is to put in your current injectors into the slopes and then load the pro-m maf curve that matches up with your maf. This gives the computer the facts and will help your drivability.CManT1914 said:Zero Signal, I got a question for you (or any other twEECer user really).
If I have 30lb injectors on my motor, and my MAF is calibrated for 30lb injectors, is there any need/benefits from setting the injector slopes with the twEECer?
From what I understand, a calibrated MAF is basically a MAF that sends the computer a "tricked signal" so the computer thinks there is more/less air coming in than there really is. So if I then proceed to set the injector slopes and tell the computer I'm using 30lb injectors, won't it get wrong readings again?
Where are they and what do I need to change?
